Volvo Voltage Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by InmanFreight, Jun 8, 2016.
  1. InmanFreight
    InmanFreight Light Load Member
    53
    56
    May 17, 2015
    2005 Volvo VNL 630. Always had a rock steady 14.4 volts on the gauge when the truck was running. Now I'm bouncing around between 13 and as low as 11.7. Multimeter still shows a consistent 14.4 coming out of the alternator and pulled the batteries and had them checked and found to be good, 12.4 - 12.5.
    So, now I'm assuming some type of wiring short or ground problem but the main cables going from the batteries to the starter seem to be good and tight, don't know where to go from here. Anyone run into something similar or have a suggestion? Thanks
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,476
    6,513
    Aug 26, 2014
    Take a volt meter and check, turn on A/C, lights, etc. Alt. housing to engine , engine to frame, frame to cab, frame to - battery terminal. Jumper wire and + battery terminal to starter stud, starter stud to alt. stud, battery to fuse box supply etc. Check grounds in cab etc.
    InmanFreight Thanks this.
  4. InmanFreight
    53
    56
    May 17, 2015
    Thanks, I may have found it. The positive starter lug was not as tight as I originally thought. I got a few good ratchet turns on it. Seems like my fluctuations might be gone. Hoping that was it...
    Edited to add: That was my problem, all is good now.
    Bains, 04 LowMax and Dave_in_AZ Thank this.
  5. Dave_in_AZ
    388,512
    I had a truck try to go into a parallel dimension once, almost brand new truck. Stopped, no one that put it together at the yard ever thought to tighten the battery terminals or interlinks.
  6. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Clean and tide batt pols
    Then check the tin cable at the altinator
  7. walec49
    walec49 Bobtail Member
    Here is my problem...
    Vnl, when running with Ac on voltage drops to 13.3,when Acs off gets up to 13.9
    I may shut the engine off and it won't start,then suddenly after couple minutes all is good.
    Batteries, alternator checked,both fine.
    Any ideas?
