Volvo vs Freightliner. Buying Truck. Please Help.
Discussion in 'Ask An Owner Operator' started by screwemissions, Dec 27, 2017.
  1. screwemissions
    screwemissions Bobtail Member
    5
    4
    Dec 27, 2017
    we just posted somewhere else but we don't know how to move the thread. This seems like a more appropriate forum for what I'm asking.
    As you can deduct from my username, I'm strongly against egr/dpf. However, I am forced to get a newer model truck. I've possibly read every single thread there is on this site about different trucks and have come to the conclusion that all newer model engines are plagued with ECU/EGR problems. A little back story; I plan to team drive with my wife on a dedicated route, mainly southeast (Tennessee to Florida) pulling a dry van, mostly under 80k lbs. From what I deduced from my research, the most reliable trucks/engines would be Cascadia's DD13 (have heard a mix of horror stories, and people that "just got lucky" on DD15s) and Volvo's D13. Automatic is preferred (a happy wife a happy life).
    I know to stay away from both manufacturers 2012 and under models, as they are more common with EGR problems. Volvo pros; seem to be more reliable, very comfortable (might help with team driving), Ishift leagues ahead of DT12. Cons, about the only ones I can find are the known injector cups which to my knowledge have been fixed. And, more expensive parts and greater down-time. Cascadia pros; larger availability of service locations, cheaper parts, and some success stories where the truck has had no major breakdowns. Cons; Rougher ride (comfort), and the horror stories, that can really scare a young starting owner operator like myself.
    My family has been in the business for over 10 years and we have established dedicated clients. I know the ins and outs of the trucking industry as I currently have experience with dispatch, loads and driving. I've ran the numbers and I can afford about a 60k truck. Any real world tips, recommendations, anybody that has had both trucks and can point me in the right direction, I would greatly appreciate it. I've seen on these forums, that the members are very tight knit community, and am happy to finally be a part of it. Thanks in Advanced, Safe Driving out there!
  3. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,293
    Sep 12, 2017
    Plymouth MI
  4. Brandt
    Brandt Road Train Member
    4,506
    6,168
    Sep 17, 2012
    Volvo was using brass/copper something injector cups. Not sure if the switched to stainless steel I heard there were going to.
    I had 2011 DD15 I'd was a disaster with all the repairs it was a used truck with warranty. I'm driving a 2017 company truck with DD13 got it brand new and it been a good engine so far at 156,000.
    From what I read and hear the 2014 and newer engine are pretty good. Watch out on the older ISX they had LOTS of trouble with top cams going out because all the soot was clogging the oil ports.
    AlexD13, 10speed4me and screwemissions Thank this.
  5. crucar1800
    crucar1800 Light Load Member
    186
    71
    Sep 21, 2012
    give cummins ISX engines a good look. They seem to be super fine as long as you give them care and preemptive maintenance. The problem with overhaul jobs needed seem to come from dirty fuel not the engine failing.
    Justrucking2 and screwemissions Thank this.
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Had a few volvos with cup and injector issues...
    Fl has more room and i think a better engine..
    Volvo has better interior quality blows away fl and the i shift is by far better..
    Im a company driver and a cpl yrs ago i was thrilled to get a fl but now im on the fence..
    The dd15 has been a dream smooth and quiet good on fuel but seems laggy as hell based on the broad ppwer ban..So far only issues with fl are
    Drafty by drivers door,laggy power,interior is not to bad and had a belt pully go on me..265000 mi and im still fairly happy...If it were mine,i would be pittsburge power bound lookin for an ecu tune to wake this thing up..Maybe find a tranny tune as well..
    Big bunk volvos are heavy,keep that in mind to
    screwemissions Thanks this.
  7. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Both the newer Volvo and Freightliner are decent trucks . I have a 2014 for 1 yr with no emission problems minor issues here and there but its been good to me .
  8. Aamcotrans
    Aamcotrans Road Train Member
    1,045
    1,804
    May 24, 2016
    Strasburg, Va
    The ISX has severe issues with the fuel pump tappits wearing the cam lobes off, resulting in massive metal, which results in hole in the block. There is a campaign based on serial number, but no recall, and no coverage for progressive damage. Motor blows, you’re out 40k.
  9. PandaPancake
    PandaPancake Light Load Member
    225
    272
    Dec 23, 2017
    I have a 2012 cascadia. There was a fire sale on them and myself plus another four picked some up from Utah to run oil. My only piece of advice in the short time I've owned the truck is once it calls for a regen pull over and let it regen. I'm doing lots of short hauls, slow speeds, and I had a check engine light for the doser come on. I pulled away before the regen finished. It didn't derate me but about midnight it called for a regen. Pulled over let it do its thing this morning the light was gone
  10. Brandt
    4,506
    6,168
    Sep 17, 2012
    If anyone wants to learn about the ISX engine this guy shows everything. Including the two different engines and how they work the problems the ISX had.
  11. Ridgeline
    22,400
    116,435
    Cummins has a habit of ignoring engine defects, they did this with the 12 vales baby cummins in dodges a while back with an improperly designed dowel pin that can pop out and go right into the gears.
    So far I have had good service with my ISX trucks, they've held up better than the cats and others I've owned in the past, no really big issues that plagued them so far. I can't speak for volvo, I only had one or two that came in a deal and drove one for a week back and forth to the storage yard to put a little bit of miles on it before it was sold, it was nice but it is nothing to scream about.
