Volvo VT880 question
Discussion in 'Volvo Forum' started by swfla, Mar 17, 2014.
  1. swfla
    swfla Light Load Member
    98
    19
    Mar 10, 2014
    I can't remember if there was a reason why they stopped producing the VT880 does anybody know why. Sure was a nice truck.
    rabbiporkchop Thanks this.
  3. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    I remember reading somewhere a big issue with them was weight. Not sure if that is a valid reason or not, just something I ran across after searching for answers as to why they were no longer producing them, when I couldn't find the truck on their website.
  4. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Weight Issues and Slow Sales were the factors that led to the decision to discontinue the VT880.
    rabbiporkchop and KB3MMX Thank this.
  5. swfla
    98
    19
    Mar 10, 2014
    Thanks I appreciate it. One sees something they really like and it's not available. I never really paid that much attention to Volvo until I started noticing these 880's. Still looking and researching the new trks.
    BobcatVolvo Thanks this.
  6. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    I love the 880, they are a little heavy on the front. They were meant as a owner operator heavy haul truck available with 625 horse and 2250 torque, a 625 c-16 cat only puts out 2050 torque so that's impressive, to handle that power eaton custom designed a rtlo22918b transmission to handle it.
    Sales ended up tanking it because they had huge injector cup And turbo issues which made o/o's stop buying. It turned out it was a internal issue with the turbo company and they fixed the problem and after 2 different materials they solved the injector cup issue. A little too late now.
    If you look online for volvo 880 you will see tonnes of bad reviews all to do with the d16 (which is why it still has a bad name) but if you notice all those reviews will end 2009-2010...... Everyone tells the world when their truck breaks every other day but not when it's running perfectly, probably cause they're too busy working. Haha
  7. BobcatVolvo
    BobcatVolvo Light Load Member
    171
    132
    Feb 23, 2014
    Western Ohio
    Absolutely love mine, and have had very few problems. I think early bugs killed it. My next truck will be lighter, but I cant say the extra weight has cost me any loads, and I will say the extra horse power has landed me a couple loads.
    Blue jeans, rabbiporkchop and KB3MMX Thank this.
  8. swfla
    98
    19
    Mar 10, 2014
    I just got back from going with my friend from Ga to make his delivery just miles from my house in his New Mack CHU613 Rawhide edition with Mdrive and 505 Up. He knew I'm in the Market for a new trk. I don't know how to explain it other than what a ride. Hardly no outside noise, pulled very good. Mdrive was flawless. Very impressed. Air will freeze you out. Great sounding stereo plenty of room I believe it's a 70" sleeper. Funny thing he had KW'S for over 20 years. He seems very happy with Mack. Just saying.
    HammerDown247 and KB3MMX Thank this.
  9. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    Those 660's are sharp trucks, bit tight in the sleeper but hell, with the front cab curtain you can't complain too much. Stay away from climacab if you can reasonably do so. Never ran one with a Detroit or Volvo in it, but the Cummins will pull and pull until the wireharness almost quite literally begins to fall out of it after it turns 6, and the ECM follows shortly thereafter. Eaton Roadmaster- loved it. Ran great, always turned over and always pulled as hard as I asked it to within reason. Biggest complaint would be a chronic issue I had with my fifthwheel- Volvo installed one that must've sat in a wet part of a warehouse, somewhere, for a long while- it rusted out and they just repainted it (though this could've come from, I think it was, Holland?) So every time I went to drop a trailer, she'd jam like you wouldn't believe unless it was on completely level ground. Dropping a wagon in a ramped door? Well screw you!
    Eventually company ended up replacing it because of all the issues I was having with it.
    Other than that, they're super comfortable. Wide bed berth, plenty of storage. GREAT, AMAZING, SUPER suspension. Rolling a Volvo is like driving down a smooth road in a Cadillac- huge/massive difference from a freight shaker or international. She rides smooth. Nice built in fridge with freezer combo, plenty of outlets.
    And I won't lie, I like their shape. The whole fender/running board combo makes it look like a truck cab sitting ontop of a large/wide frame with a nice sleeper cab sitting ontop.
    I'm the kind of driver that before the most recent DOT changes, would push 11 hours straight in the hot seat without stopping once. It was not a pleasant thing to do in say, a Cascadia. It was a joy do it in a 660. Then, when you're exhausted from working 11 hours you climb into your comfortably arranged, well ventilated, and thickly insulated sleeper and get a solid 8 hours.
    I really can't speak highly enough of how well a Volvo truck is made.
    And wait for it; someone's going to reply with the complete opposite of this post :biggrin_25515:
    Some edits? Sure!
    Here's a few downsides.
    Maintenance, not PM's but specialized Volvo maintenance was hard to find on occasion. Two occasions to be exact. Had a bit of a problem with my clutch break when I first got her (another driver had her for 250,000 miles before me and ground the clutch break into oblivion. TAKE NOTE; NOT ME! :biggrin_255:) And the other being the Jake malfunctioning as a direct result of the clutch break going out, had a spring in the clutch assembly that had a little issue and wasn't allowing the J to engage. Not a fun thing to find out when you've got 40,000 on the back and are heading down a rather steep hill. The service breaks had to take the hit on that one. After I managed to get it into the shop, though, quicker than you'd expect to get her back out.
    Parts can be a pain, Cummins parts are easy to find. But if you need something like fifthwheel or suspension parts? Well, let's just say it's good to be patient.
    Weight in the front- it's a bit high. This worked out well for me when I would have to hail marry loads up to NYC from Philly. "Sorry boss, she's 500 over on the steers." And just chuckled. I know, terrible person.
    HammerDown247 and BobcatVolvo Thank this.
  10. mhallam
    mhallam Light Load Member
    61
    36
    May 15, 2012
    Saskatoon, Saskatchewan
    I had a 06 880 with the 625 2250 ft lbs. 3.43 rear ends. It was a great truck to work in, a bit top heavy in wind. It swayed a lot side to side. Rode like a dream. However the d16 was unbelievable. That was my lesson in trucking....never ever buy a new model year engine. My first year was flawless, almost to the day it turned into a truck that wanted to be in the shop literally 8-10 days a month.
    From injectors and turbos to belt tensioners, wire harness you name it. Cracked fuel filter housing, pickup line in tank broke off, radiator, AC condenser split for no reason, xantrax power inverter died 3x. That's just what I remember now lol
    i know the engines have come along ways, since then, I've talked to tons of guys who actually don't bs about fuel and reliability and the d16 is the way to go.
    Its unfortunate that for every bad d16 story that there's prob 20 good ones we rarely hear about.
  11. The_Judge
    The_Judge Light Load Member
    257
    68
    May 25, 2008
    Montreal, Quebec
    VT880 had the most complains ever since Volvo open shop in USA. It was not coz of the VT, it was coz of the D16 engine. While in Europe it was a fantastic engine here they modified it and the result was total failure. The problems they encountered with the new D16 were so numerous and happen to so many customers then they realized it is better to stop the mass production.
    The VT as a whole truck is a heavy critter and the extra weigh cuts from the pay load. It was always meant for O/O and not for fleet. God knows what other reasons have been they stopped the production.
    One thing I know for sure: I love my VT880 and I'll drive this thing till it would be illegal. Is already illegal in Kalifornia so I enjoy it as much it has left until other socialist states will follow the example.
    KB3MMX Thanks this.
