volvo warning lights
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by bam the driver, Jan 24, 2018.
  1. bam the driver
    bam the driver Bobtail Member
    I currently drive a volvo. The batterys, and starter have been replaced in last six months. The red battery warning light just came on today but voltage readout says it stays steady while driving between 13.6-14 volts. While sitting stays between 13.8-14.1 volts. While going from stop at red light to speed limit pulled a little too hard and truck shut down then i restarted it without a problem. Does this mean the alternator is starting to go bad or a possible connection error in the electrical assembly?
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Well, sounds like an electrical issue somewhere. Sounds more like the ECM is losing power or is grounding out somewhere then "un-grounding" back out.
    Check ground cables, especially the one from your starter to your frame. Clean really good, posibbly replace it if it's questionable. Check your power supply to ecm. Look over wire harness really close, especially at points where it twists and turns or goes over/ makes contact the frame and etc
  4. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    This is in the ELog and ELD section. Do you suspect an ECM plug problem (as provided by your eLog device provider) is causing this?
  5. bam the driver
    Now the light has turned off and intermittently turn back on then go back off. As far as the keeptruckin eld units connection to the ecm. Before this issue started occuring i had disconnected it and reconnected it to the ecm. I did this because my phone said they werent connected. I foind out it was actually me updating the applicarion on my phone. If this is the entire cause what could i do to keep it from happening? Such aa use my can of compressed air and blow on the connector?
  6. RollingRig57
    RollingRig57 Bobtail Member
    There is a switch in the battery area that had to be replaced on my 780 and it fixed the problem. It was not the batteries.
  7. RollingRig57
    I am trying to find out if anyone has ever dealt with a pulley belt issue and air dryer/filter. It is a 780 and I am looking for possible price and possible labor costs?
