Hello everyone, I have a 2006 Volvo with autoshift transmission ,VED 12 Volvo engine. Problem I have is Crank longer before start. Any body in Detroit MI area working on this engine beside dealership. I research forum and talk with my friends :could be injections,cup, fuel pump or so,so,so ,so. Thanks.
Volvo with VED 12 engine
Discussion in 'Volvo Forum' started by Esko, Jan 3, 2014.
I'm not a fan of dealerships but in this case I would have them diag the issue. They can plug in their computer while you have the symptoms and tell you what it is really quick. Then you have a coice to have them fix it or a local indy shop. Going to a small shop first will have them throwing parts ($$$) at it and guessing. That's what i'd do, anyway.
+ nationwide warranty on the repair and parts. FYI.
*No I don't work for Volvo, just sayin' -
I Had truck in Maumee OH Volvo dealership and they don't know for sure ,maybe cap, maybe injections they don't know, I read some post of the member here at forum he spend $28.000 on his truck and still have problem I don't want to go for that, I'm hope I can cross to some one who work on side on this engine. I had tune up last year in Chicago dealership they open 24 hours and they did job good and in time ,but here in MI you can't even got appointment in 7 days, they suck because they don't have competitor ,thanks for respond.
Mine was a little newer but had the Volvo engine and was doing the same thing they had to replace the injector cups and 2 of the injectors. It kept taking longer and longer to start and got progressively worse until the fix. Any power loss with the hard starting once it's running?
crank position sensor or camshaft position sensor.. then I would go with all the fuel "stuff" you mentioned
any crank ore cam sensor problem and U have stored fault codes. I sugest fuel check valve
Volvo d12 are the most efficient pre-dpf engine Volvo built. My uncle gets 7+MPG on Volvo.
if you crank and crank on cold or first start but then it will start ok after that. It more then likely injectors they are leaking down over night so you must crank to get pressure build back up. VIP volvo is the worst shop around and would not have them work on it. Just do not know a good volvo engine man around Detroit. M&K volvo over in GR is a good shop.
I would rather fix that engine by myself than bringing it to the shop.
Quote:> Spent $28.000 on his truck and still have problem.
If that is true, which I doubt, I have some property to sell him.
