volvo670 fault codes help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mahittsingh, Jun 18, 2015.
  1. mahittsingh
    mahittsingh Bobtail Member
    12
    Hello everyone
    I have 2006 volvo 670 Cummins isx 475 with these codes:
    MID 140 PID 118 FMI 6
    MID 128 SID 27 FMI 3
    if someone can help decipher them please.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    MID 128 is the engine ECU, SID 27 is the VGT actuator, FMI 3 is low voltage.
    I don't have a list for MID 140. All I can tell you is that MID 140 is the instrument cluster and FMI 6 is high current. I don't know what PID 118 is though, so I can't tell you what has high current.
    Pablo-UA is good with Volvo's and he hangs out in the Volvo section, you might get some better help in there.
    mahittsingh Thanks this.
  4. Bogi
    Bogi Light Load Member
    114
    31
    Jul 15, 2013
    Elk Grove Village, IL
    ECU is powered directly from batteries, there is thin red wire with fuse on it. If it's autoshift there is one more powering transmission TCU. Check these cables, right on batteries.
  5. mahittsingh
    12
    Whatz happening is secondary air buzzer comes on air drops to 0 or 60 or 20.. sometimes it does that for a while and then all of a sudden it goes back to normal. I noticed when I hit a pothole or when itz windy or when i m changing lanes..it happens. When sitting overnight it starts bk normal n morning. Andy cab air leveling valve is not working. Could it be that?
  6. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Mid 140 pid 118 fmi 6
    Secondary air pressure transducer
    High voltage
    Not sure what this part is but it seems to be electrical in nature. I would guess that you have a wire shorting out somewhere. That would explain why it does it on bumps or turning.
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Secondary air pressure transducer would be the sensor that converts the air pressure to an electrical signal to the gauge. Not sure where it is on a Volvo, but you need to find it. It may just be a bad connection on it, could be a wiring problem or the sensor failing. Good chance that you'll find a bad connection in the circuit, judging from it changing when you hit bumps.
  8. mahittsingh
    12
    Thanx everyone...found the problem...it was the sensor.On the driver side if you take out the bottom panel by the brake pedal behind it you will see two sensors on the firewall. Sensor on the right was bad. Take it out and replace it. It cost $90. 1/2 hour job.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    First of all u have bad wiring ore bad air pressure sensor of rear brakes
    And as usually EGR problems
  10. mahittsingh
    12
    Actually the problem creeped up again...guage would still drop but this time i unplugged the sensor i had changed and plugged it back and everything is normal. I think its a short circuit somwhere.will try to trace it up to the cluster this weekend and update you all.
