W900 Cat C15 SDP Fuel Filter Gauge Question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Adamali21, Dec 11, 2020.
  1. Adamali21
    Adamali21 Light Load Member
    278
    180
    Jul 24, 2018
    Why does my fuel filter gauge has a solid red light and even after a fresh oil change it still has that red light on. The photo is at cruising speed 67 mph and it’s at 14 INHG, now is that normal or is there a sensor issue and where is that sensor located 2010 w900 Cat C15 SDP
  3. AModelCat
    158,343
    Was the fuel filter changed?
    p608 Thanks this.
  4. Adamali21
    278
    180
    Jul 24, 2018
  5. Adamali21
    278
    180
    Jul 24, 2018
    Yes it has every 10,000 miles
  6. lester
    2,919
    7,879
    Jan 2, 2012
    NW, Iowa
    Was it reading that high before the filter change? Do you have a fuel pressure gauge?
    Can someone tell me how that gauge works or where its plumbed in? I know its a restriction measurement but I've never understood from where. Everything after the pump has positive pressure and obviously the draw side has negative pressure but not sure how that would be affected by filters.... my truck has that gauge but it has never worked and its in the dumbest spot behind the steering column
  7. Opendeckin
    Opendeckin Medium Load Member
    452
    1,261
    May 20, 2018
    If that's correct you're going to be Dead in the water soon. I've gelled up before and the truck sputters a bit past 15 INHG and completely shut down somewhere around 20. it should run around 2 at idle and 4-5 at full throttle. You need to confirm that all fuel filters are new if you didn't put them on yourself.
    Assuming the sensor is reading correctly (if the gauge is steady it probably is) there's a # of different reasons that your fuel system is building excess vacuum.
    -Algae in the tanks is causing filters to prematurely clog
    -You got a bad load of diesel that prematurely clogged the filters
    -The fuel lines are swelling or collapsing (unlikely given the age of your truck)
    -A tank vent line is clogged
    I had a bit of an oddball situation myself recently where My vacuum was getting up to 8 on a heavy pull in cold temps. I suspected a build up of paraffin wax in my fuel system to be causing this as this had gradually gotten worse for years and showed itself as a problem primarily in cold temps so I dumped a bottle of 911 in each tank and topped them off with #1 and the numbers are back to normal now so that's another possibility.
    Adamali21 and black_dog106 Thank this.
  8. Adamali21
    278
    180
    Jul 24, 2018
    So what are the steps I should to to figure this issue out, fuel filters are brand new, could a sensor trigger this issue, what should I check to figure this issue, I don’t want to ignore it and then stall on the highway somewhere.
  9. AModelCat
    158,343
    Start with a fresh set of filters and go from there. A tank of crappy fuel doesn't care how new the filters are.
    Opendeckin and Adamali21 Thank this.
  10. Adamali21
    278
    180
    Jul 24, 2018
  11. AModelCat
    158,343
    You do you. I'm just suggesting the easiest starting point.
    Roberts450, Opendeckin and Adamali21 Thank this.
