W900 L speedometer question ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sunsation288, Oct 25, 2014.
  1. sunsation288
    sunsation288 Light Load Member
    55
    54
    Jan 12, 2014
    Hello all , i have a KW W900L , with a 3406e , and the speed reading work ok (the needle read the right speed ) but the odometer not incrementing ? ,
    my question ?
    the sensor on the output shaft of the transmission go to ECM and after that the ECM produce only one pulse for the speedometer / odometer ?
    hope my question made sense ?
    if not feel free to ask
  3. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    Yes, you get one pulse for the whole speedo head...if your odo is not working you need a new head.
  4. sunsation288
    55
    54
    Jan 12, 2014
    Many thanks scrapper !
  5. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    There are some aftermarket speedo heads on Ebay. They are ALOT cheaper than the ones from kenworth. We have found them to work very well. I do not remember the seller. They had quite a few on there. The customer service was good also.
  6. 6nz-kw
    6nz-kw Bobtail Member
    48
    13
    Dec 28, 2013
    Jamestown OH/Holly Hill FL
    D and D speedometer,will fix one for about 200 bucks !
    Scrapper Thanks this.
  7. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    6NZ got it...it was D&D....thanks for that. That is who we got our new ones through.
  8. sunsation288
    55
    54
    Jan 12, 2014
