W900 questions
Discussion in 'Kenworth Forum' started by Slingshot88, Jan 4, 2018.
  1. Slingshot88
    Slingshot88 Bobtail Member
    20
    39
    Mar 23, 2017
    About to dump my shaker columbia in a couple months and pull the trigger on a w9, looking for input from owners as to w9-specific things to be aware of/watch out for when looking at a few of these trucks. Best looking trucks on the road imo, and I've been inside a few of em but never driven one so idk about certain quirks they may have and whatnot. I pull dry van and I usually run the midwest and south, never northeast, so I don't care about the wider turning radius. Looking to spend up to about the $50k range, preferably closer to $40k though.
    Here's the things I know for sure that I want in the truck:
    1. 1990s model year (so I can go back to paper) preferably a 99 just so it's the latest one of the decade while still being exempt
    2. Cat 3406e with fairly recent overhaul
    3. 13spd
    4. 3.55-3.70 gear
    5. Standard sleeper, no flat-tops
    What differences were there in model years during the 90s? Can't seem to find any specific info on the whole internet regarding the aesthetic and functional differences between W900 model years. Which suspension should I want, ag200 or ag400 or something else I'm not aware of? As for the 3406e, what is the better one between the 2ws and the 5ek (or 6nz if that was available in the 90s which iirc it wasn't until 2001)... Also I've heard that the hoods sometimes shake at certain speeds, wondering how common of a thing this is, and also wondering about the fit and finish of the truck in general. I've only ever driven Freightshakers so a sh**ty ride quality is all I've ever known or experienced, not to mention the constant squeaks, rattles, and wind drafts coming in through various nooks and crannies all over the truck. I'm figuring that even a bad W900 has to be a world better than an average Freightliner. And what about the wiring, are they known for any electrical issues? Also, how much worse is the fuel mileage for a cat-engined largecar vs an aero/plastic truck, is it a noticeable difference? My columbia (Mercedes motor) usually gets no better than high 6s if pulling very light over flat ground, or as low as 5.3-5.4 if pulling 45k over some hills. I can't imagine a largecar being much worse than this, aerodynamic or not, but correct me if I'm wrong.
    Basically for $40-50k I would think that'd get me into the territory of VERY well maintained 1990s w900's that have had recent overhauls and have good interior fit and finish, does this sound like the appropriate price range to expect a lot of W900 for my money?
  3. pavrom
    pavrom Road Train Member
    3,182
    7,295
    Apr 29, 2012
    NE illinois
    I have 99 with acert c15 inside , Jones hood with shaved lights , got 389 lights installed , 13 speed
  4. pavrom
    3,182
    7,295
    Apr 29, 2012
    NE illinois
    U got me thinking to sell it
  5. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    If you find one with the AG200, make sure it's cheap enough to upgrade it to AG400. Cost me in the neighborhood of $3,000 to do my '99, with an alignment. The AG200 is junk in my opinion.
    Yes the hoods can shake some but unless you're tryin to drive a show truck it isn't a big deal.
    I can't help ya with the yellow motors. Sorry.
    Slingshot88 Thanks this.
  6. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    They don’t shake on a flat glass W9 with a box sleeper. On an aerocab W9 you will motice movement because of the cab/sleeper suspension. At first it will drive you crazy but after just a short time you won’t pay any attention to it.
  7. Rugerfan
    Rugerfan Road Train Member
    7,326
    36,148
    May 3, 2011
    Redding,CA
    With only running Midwest and south, why not lower the rear end gears? Maybe like a 3.36 or so? Seems 3.70 or 3.55 would be a tad high.
  8. hellpatrol
    hellpatrol Light Load Member
    221
    172
    Apr 22, 2013
    definitely check for the AG-400. I don't run one, but everyone I talk to says that or nothing. it could be a deal-breaker if it's not a 400
    stwik and ShooterK2 Thank this.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    As far as ELD goes the way I understand is they are going by build date/EPA classification of engine. Needs to be pre Jan 1, 2000. A couple 6NZ did sneak thru as EPA 1999. The lucky ESN number is 6NZ04748 and below. Personally I think 2WS are just as good, just don't have the updated block and sealing improvements.
  10. Slingshot88
    20
    39
    Mar 23, 2017
    Rugerfan you're right I could make do with a lower gear. I was just thinking 3.70 because my buddy has one with his 3406 and I like the way the truck pulls, maybe something in the 3.30s-3.40s more appropriate though.
  11. AModelCat
    158,346
    200 can be converted to 400. If it has the 200, just plan on spending the money to update it once the 200 wears out. Why spend money to fix what isn't broken? I'm not sure what the cost difference is between installing new AG200 pins vs installing the AG400 waffer bars. The center brackets, all the mounting and air bags are the same on the 200 and 400 IIRC.
    ShooterK2 and Slingshot88 Thank this.
