W900 Shuts down, changed oil pressure sensor, low voltage to ecm
Discussion in 'Ask An Owner Operator' started by JonasTtrucker, Sep 27, 2018.
  1. JonasTtrucker
    JonasTtrucker Light Load Member
    53
    Apr 26, 2018
    St. Louis, MO
    About a month ago my W900 starting to go to slow idle and when pulled over the engine shutoff. Thought it was a sensor or a bad computer, but in the Morning the truck started right up and ran for a month no issues until yesterday.... yesterday the truck did the same thing accept this time haven't been able to drive it. Got an error code saying oil pressure sensor and low voltage to the computer and replaced the oil pressure sensor and tried another computer with the same issue. After starting the engine sometimes a few minutes sometimes 10 minutes the engine will shutoff... any ideas?
  3. Cattleman84
    Cattleman84 Road Train Member
    9,947
    70,949
    Nov 1, 2017
    The Sticks, Idaho
    Bad connection or wire going to computer??? Just spit balling, I'm no mechanic.
  4. fortycalglock
    fortycalglock Road Train Member
    6,156
    6,585
    Jun 25, 2011
    Tourist Town, FL
    Bad power or ground to the ECM.
    boneebone and AModelCat Thank this.
  5. AModelCat
    160,754
    Diagnose it, don't start throwing parts at it. 99% of the time its wiring, not sensors or computers.
    peterbilt_2005 Thanks this.
  6. boneebone
    boneebone Road Train Member
    2,296
    2,368
    Mar 13, 2009
    Also check chafed or loose wires around the starter, battery and ECM.
  7. MysticHZ
    MysticHZ Road Train Member
    5,885
    5,696
    May 28, 2010
    Or sometimes it's what the sensor is monitoring is actually bad. My last truck had similar symptoms ... The oil pump was going.
