W900 Wiper issues
Discussion in 'Kenworth Forum' started by cumminsISB, Feb 1, 2012.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    I have a 2005 W900l with the funky wipers that start in the middle of the windsheild and sweep outward towards the edge of the windsheild. I am having problems with the blades getting stuck together. I have the required 15 inch blades. Is there a kit to convert this over to regular sweeping action? any other suggestions? I also have a issue with the speed. Sometimes delay and low works, sometimes they don't...high speed always works. I really need help with this as it is driving me crazy.
  3. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    nobody else has this problem?
  4. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    The speed problem sounds like a switch issue, like a fan motor, when the resistor goes all that works is high speed.
    Far as I know there is no kit to convert to a more traditional sweep.
  5. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    any idea how to pull the arms off? looks like someone had them off at one time and clocked them wrong./..gonna try that but can't get the arms off!
  6. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I had the timing of mine adjusted at the dealer so I know it can be done but I dont know how. I need to adjust mine more as the passenger side like to run off the glass.
  7. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Do you have the split windscreen? I drove a T600 with the same type of wipers, and they were always 1-2" away from the center gaskets.
  8. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    Both mine and my buddy's W900 has a wiper that just doesnt always end up next to the center of the dual windshields. They wipe fine but their HOME position isn't always vertical with the center windshield divider. Like Barroll says, 1-2" away..
