W900
Discussion in 'Ask An Owner Operator' started by Mr Bud, Nov 6, 2017.
  1. Mr Bud
    Mr Bud Bobtail Member
    31
    7
    Jun 23, 2016
    Yes theyre a fine truck and i dont need to be getting plump and jogging is outta the question used to run i 10 twice or thred times a week back in the day but now mainly. i 40 thanks
  3. Mr Bud
    31
    7
    Jun 23, 2016
  4. Mr Bud
    31
    7
    Jun 23, 2016
    Thanks for your thoughts but 308 rears would work me and the mule to death in the mountains and yes i will be running 24.5 lp i have 342 rears now with a 18 does a great job i may drop the new truck to 336
    KB3MMX Thanks this.
  5. Drake.r
    Drake.r Light Load Member
    131
    125
    May 15, 2015
    W900L 475 isx 13 speed 6.6 mpg on a few 7% hills I’m happy but a 605 sure would be nice
  6. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
  7. Mr Bud
    31
    7
    Jun 23, 2016
  8. savage02
    savage02 Light Load Member
    163
    50
    Dec 21, 2007
    Upstate, NY
    I'm running the Cummins X15 565/1850 in my 2018 Pete 389 you will be more than happy with it. I also pull van trailer I ordered it with 18spd and 3.55's on LP24.5's (I'm running in the Northeast). It's a total animal powerwise. I have 55,000 miles on it since putting it into service in May and have played around with different rpm's for cruising speed to see difference in mpg's. Max mpg's are at 1400rpm as I've tried running in the 1370 80 and 90 range and mpg drops. It is VERY happy running at 1500rpm but mpg drops about .3mpg which isn't a big deal to me (I usually keep it in the 1450-1500rpm range). Cummins rep was at the dealer when I ordered it and told me the X15 Performance series isn't designed to cruise for prolonged highway speeds under 1375rpm's. This engine needs to breathe and work, not lug at low rpm's down the highway. That's what the X15 Efficiency series is for. Not saying its the end all be all of engines but for a bone stock out of the box engine it gets after it. I have 3 buddies I run with on a regular basis that have 6nz Cat powered gliders with hot cat files in them, with the same exact trans, rears, and tire size as my setup and none of them can touch me on a hill. That being said I'm not bashing on the big kitty Cats just using them as a comparison. If your going with the 605/1850 version it should exceed your expectations.
  9. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    The higher torque rating 18 speeds will add value to the truck for resale down the road.
  10. Mr Bud
    31
    7
    Jun 23, 2016
    Nope it's gonna be 2050 performance 605 342 rears
  11. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Im just about ready to put my 2018 388 into service and running pretty much the same gearing as you. I spec'd a 565/2050, 18sp, 3.58's and 11r22.5's and will be running the northwest at 105,500 and glad to hear these engines like that 1400+ rpm range. Ive driven it a little (home from the dealer and to the install shop for my blower) and she runs real good at 1400@65mph and seems really happy at 1500@70mph. Cant wait to get 80,000 pounds hooked to it and break her in.
