Greetings all, I have 2 W900A Kenworths one is a 79 Extended hood 60" Flat top sleeper on newer pete air leaf, DS402s, (7FB)3406BATAAC Hopped up, with a fuller 9 and a spicer 1241D aux, Second truck is an 81 with a 12 yard dump bed, double framed DS380s on Walking Beam, Cummins BCII400 (soon to be a (4MG) 3406B (JWAC) with a 14610 Super 10 and 1241D aux. Both of these trucks are experiencing the same issue, the 79EXHD has never had a problem with the headlight breaker tripping until I installed a new set of projector headlights, the 81 has been tripping with the factory halogens and the new projector headlights. Both trucks when the Trailer/Cab light switch is on will intermittently short and kill power to the tachometer (not completely still reads 200RPM or so) the 79 will also kill the backlights to the speedo and tach, Its kind of strange both trucks experience the same issue in that area, Now both trucks will trip the headlight breaker with the high beams on after about 5 minutes which I am hoping the breakers are just old and weak which the 79 has all new wiring to the headlights and I cant find any symptoms that would suggest a short, (hot wires, large draw etc.) Does anyone have any experience with these breakers getting weak or anything related to these issues?? Thanks in advance: Josh
W900A Auto Reset Breakers
Discussion in 'Kenworth Forum' started by JLD79EXHD, Feb 24, 2013.
Yes, they will get weak. The more they trip, the weaker they get.
I'm not entirely sure, but I think the biggest is 30 amp. Without a wiring diagram, it won't be easy to figure out
That sucker is a beast. -
So does anyone happen to know part numbers for these breakers? And possibly where I can get them from? Thanks: Josh
Breakers are two pole, relays are four or five pole. Most parts stores carry them both.
I figure he is calling the relay's breaker's, that is the reason I posted what I did.
