W900L AC issues, will not push air out very hard.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Aug 21, 2021.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,335
    1,694
    Dec 4, 2019
    My ‘93L will not blow hard at all. The 3 speed selector works on all 3 speeds but will not blow hard. Air is cool but could stand to be colder. Last year I replaced the compressor, drier and expansion valve. It operated ok but has never been good or close to great. Considering buying a new aftermarket box that contains the blower, evaporator and heater core. Might this help?
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,826
    Dec 7, 2015
    OK
    The evaporator is likely plugged with dirt. Just needs a cleaning
    Oxbow and mile marker 27 Thank this.
  4. TheLoadOut
    TheLoadOut Road Train Member
    2,356
    11,224
    Nov 6, 2019
    I'm about to buy this myself...
    Muddydog79 Thanks this.
  5. skallagrime
    skallagrime Road Train Member
    3,853
    9,925
    Apr 10, 2012
    Indiana
    Worth it, did one truck already, have 2nd to do it on. buy the full kit with new cores and get a matched set of expansion valves seperately though, replace bunk ac valve at same time.
    Only real headache i had on that was their freeze switch, doesnt really make a whole lot of sense where and how they have it set up to go in the core.
    Only other advice i have, drilling the studs out from the engine side may be easier and less frustrating than trying to get the nuts off from the cab side and the way it bolts up instead of having a welded stud on the new box will probably require a 2nd set of hands for a few minutes
  6. MM71
    MM71 Heavy Load Member
    760
    991
    Jun 28, 2008
    AZ
    Replace the whole box. They rot out.
    Roger McG, Bean Jr. and mile marker 27 Thank this.
  7. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    they make a stainless steel replacement box complete, that is cheaper then the oem box
    Muddydog79 and mile marker 27 Thank this.
  8. AModelCat
    161,302
    Never seen a blower motor last much past a year or so on a KW without a filter. For being a brand on the high end of the spectrum they sure cheaped out on having a cab filter. Dust just eats those blower motors up.
  9. mile marker 27
    1,335
    1,694
    Dec 4, 2019
    I found a complete box, from Shoreline Manufacturing.
  10. skallagrime
    3,853
    9,925
    Apr 10, 2012
    Indiana
    Thats the one, impressive shipping imo as well, ordered on their site, was at my house 2 days later 500 miles away
  11. Inderjit
    Inderjit Heavy Load Member
    742
    721
    Sep 17, 2017
    Make sure the squirrel cage blowers are on the right way. I have
    seen quite a few put on backwards when the blower motor was replaced.
    The air volume is probably around 20% when they are installed backwards.
