I'm looking at getting into flatbedding/stepdecking. Was online tonight looking at chains and binders, and I'd like to know which size and length of chain should I get. 3/8" or 1/2", and is 20 ft the standard length. Thanks for a response in advance.
Wanna get into flatbedding
Discussion in 'Flatbed Trucking Forum' started by Lunchbox7159, Dec 8, 2012.
Page 1 of 4
IMHO I would go with 12 3/8 chains 20 ft long and then get 6 rachet and 6 snap binders cause in some instances snaps are nicer then rachets. I personally havent run in to the need of 1/2 chains except for the fact of using less chains.
Lunchbox7159 Thanks this. -
I'm with Hor's I personally keep 8 chains and 8 ratchet binders on my trailer now, but i pretty much know what my company hauls and that i wont need more than 8...
The other thing you have to consider is the type of trailer you are going to yanking around. Check the wll on the tiedown points because if they are only 5400 lbs then what good is it to have a 6400 lb chain hooked to it when you still can only calculate for the 5400.
Man I appreciate that. I was starting to smoke my brain trying to figure out what would be best. I'm pulling a tank now but I did some flatbed/heavy haul in Iraq and fell in love with it and I'm possibly thinki NH of making that my next career move.
yeah i carry 12, 6 of them are 5/16 chains with 6 snap binders then i have 6 3/8 chains with 4 rachets and 2 snaps. (I would really like to have 6 rachets but since we just started getting them i will take what i can get)
You dont use 1/2 inch chain on a flatbed (except for one of those heavyhaul setups where you can hook the chain directly to the beam). Well, you can, but your average flatbed stakepockets and spools are only rated between 5000-6600 lbs. Whats the point of dragging such heavy chain out when it wont give you more WLL per securement point than 3/8 chain?
I'm looking at buying a step deck. Stopped at TMI in Dry Ridge KY last week and looked at some trailers. I was leaning towards Fontaine but the salesperson I spoke with told me that Reitnouer would be a better buy because of the construction of the trailer. He said that bolting was better than welding.
So basically 3/8" chain will do the trick for the majority of flatbed/stepdeck loads that are not heavy haul, right?
Page 1 of 4
