want a wet system and dry bulk system on same truck
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Speedby75, Jun 13, 2022.
  1. Speedby75
    Speedby75 Bobtail Member
    Is there a certain tranny associated with a certain truck manufacturer for this set up ? with 2 pto set ups, how can i achieve this ?
  3. haulhand
    haulhand Road Train Member
    Why not a hydraulically ran blower? Then you can switch your wet kit to run it or whatever else just make sure you've got a good cooler for the oil.
  4. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    check out hydra pac and S&S make a hydra pac unit both are very good and simple setup.
  5. RockinChair
    RockinChair Road Train Member
    5,227
    13,484
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Just make sure the hydraulic system can produce enough torque to start the blower.
    wis bang Thanks this.
  6. AModelCat
    161,297
    Why can't you run both off a single PTO pump? They make valves and parts that can achieve this.
    NightWind Thanks this.
  7. RockinChair
    5,227
    13,484
    Feb 19, 2012
    You can, if both units require the same pressure and flow rate.
  8. wis bang
    wis bang Road Train Member
    3,428
    4,066
    Jan 12, 2011
    Levittown, PA
    You need the correct PTO output speed for each application.
    If not using a Hydro pac you need two PTOs, one set up for each.
    Your blower needs to turn a lot faster than a product pump.
    Adding a air compressor needs a third PTO and complicates things.
    There are transmissions set up for left, right, and bottom mounted power take offs but with the DEF system and fuel tanks, running three might be a massive headache.
    Also be aware that some mega trucks might have the interior gear that drives the PTO omitted from the transmission.
    Any company buying a few hundred tractors has the ability to reduce costs by omitting 'un-needed' items and loose weight too.
    I've seen guys run into the missing PTO gear as they went to transfer their old setup to another horse only to find they have to get the transmisson re-worked.
  9. AModelCat
    161,297
    Easy enough to step down the flow/pressure to match the second system. Its done all the time on heavy equipment.
  10. Cat sdp
    Cat sdp . .
    21,180
    75,051
    Apr 8, 2012
    Orion's Belt
    Drum hydro pack for the blower , and separate hydraulic pump for the dump trailer…. It’s the easiest way. And it won’t be cheap .
    I always use D and W diesel in Albany NY
    D&W Diesel
  11. GreenPete359
    GreenPete359 Road Train Member
    2,167
    5,128
    Oct 21, 2017
    Driving my recliner
    I don’t know a whole lot about it, but we used to have both wet lines & pto driven vac pumps on our trucks when i hauled haz waste. I could drag a tank wagon today and a dump or rolloff tomorrow.
    Trucks were off the lot, nothing fancy.
