Want to convert my single screw to a twin…
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shabadabado, Mar 11, 2022.
  1. Shabadabado
    Shabadabado Bobtail Member
    Mar 11, 2022
    I haves an 05 Columbia with a single drive axle, and want to open my options on loads up by adding an axle. Obviously this would be a fairly involved process, but is it possible?
    Would it be as crazy as it sounds? Sure seems I’d be better off putting money in the truck I have than trying to win the lottery of finding a good one I can afford. The next concern would be what would it cost?
  3. 201
    201 Road Train Member
    12,334
    25,215
    Apr 16, 2014
    high plains colorado
    I'll field this one, there are so many trucks out there today, it's foolish to alter the one you have. If you must, and there's enough frame, I'd go with a liftable tag axle. Unless you do off road, which I doubt with a single axle, that extra drive axle is wasted money. A tag, or "dead axle", can be installed at a fraction of what it would take to put another drive axle in, can be lifted to save tolls, and tire wear. Good luck.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Measure other trucks to be sure you have enough room, and you will have to move the 5th wheel slide forward or add one it's a non slider, if you pull a 53 ft. With the set back pin,???? you'll have to make sure it clears the back of bunk after its centered between drive axles?
    Hammer166 Thanks this.
  5. gentleroger
    gentleroger Road Train Member
    7,455
    20,271
    Jun 1, 2010
    A quick search makes me think you'll be looking at about $4,000 in parts and about the same in labor. Putting that kind of money into an 18 year old truck is asking for trouble, imo.
    Wait 6 months and I think you'll find a good price on a reliable truck.
    201 and buddyd157 Thank this.
  6. Chinatown
    Chinatown Road Train Member
    74,952
    170,834
    Aug 28, 2011
    Henderson, NV & Orient
    I know a guy that did that. He bought a single screw from Mayflower Moving Company, then bought another axle at a truck junk yard.
  7. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    You ever thought about a cut off ? If your in the midwest I would recommend Vander Haggs
    little cat 500 and Brettj3876 Thank this.
  8. LoneRanger
    LoneRanger Road Train Member
    3,675
    9,541
    Jun 3, 2018
    Since I run very light loads, I was wondering if my third axle can be modified to lift when I don’t need it. Seems as though it can?
