I'm going to be using my 1999 freightliner fld120 for pulling a 19000 lb RV fifth wheel trailer. Truck is now set for 430/ 470 hp. Fuel milage 6.5 MPG,
Question: If I reduced the HP by 100HP to 350 will my Fuel milage go up? Seeing I'm not pulling 80000lb, would there be a increase in MPG, I know the 350 hp would still be more than enough to top the mountains at 65 0r 70. I just would lke better milage.
If you could help me please do so, Thanks
Rich
Wanting better MPG
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 1999blue, Feb 3, 2009.
I have found "the more HP the better the MPGs"
Its all down to the top 6 inches and the right foot
6.5 is respectable. You want more?
go to detroit thread .DD14 can help you. there are things that can be done.
go to a single drive axle, less weight, less gears, less rolling resistance
Low pro tires or super singles.
Fewer gears.
Direct drive with tall gears. -
I think there are better ways to get a little more feul economy that dereating your engine.I have gotten in the middle 6's at 70-80,000lbs. with twice that hp.Not knowing much about your driveline I would suggest making sure your air intake system is good,use an air restriction gauge(not an indicator).If that is good then make sure your CAC is not leaking(connecter hoses to).If all that is good check your feul pressure,it should be no more than 65psi. no load at 1800rpm.If it needs to be adjusted just replace or drill out the restrictor fitting on the back of the head which is .80 from the factory .90-.105 should get you close but check it with a gauge.The next thing is to make sure your overhead(rockers and injectors)is set correctly.If you are using this truck mostly during good weather I would also have ribbed type (steer tires) drive tires,this helps alot.If you do not mind a little more exhaust sound then you should consider a lower back pressure muffler,this frees up the engine a bit it will give a few 10ths. of mpg. It's a start!
stranger Thanks this. -
Good post above. Also, keep your foot off the throttle pedal. Use progressive shifting. When starting off, just get the truck rolling before going to the next gear.
You don't need to touch the govenor in any gear except maybe 9th with no more load than you are pulling.
Always ease down on the throttle. When stopping, back off the throttle and ease up to stops.
A trained foot can always get better fuel mileage than the cruise in rolling terrain. Use cruise on flat land.
In hilly areas, ease into the throttle before the uphill grade to get the turbo spooled up, ease out of the throttle just before the top, even if you lose a few MPH. Get completely out of the throttle at the top of the hill and let gravity get the truck up to speed.
These few tips can show an increase of .75 to over 1 MPG easy.Last edited: Feb 4, 2009
The Challenger Thanks this. -
I really thank all for their input. 60 series is all new to me, I had MCI buses with 8V71's , drive them like you hated them. I'm impressed with the fuel system and the ease of handling. I have plenty of maintenance to do, as the last owner was a slob and I think never greased or did any preventive maintenance, The cab reflects he was a slob. I stripped the sleeper and pulled the seats, installing captain steel case seats on the air ride posts, recover the dash. Complete brake overhaul next week. I'll use the suggestions as a guide, so everything helps put this truck back into prime conditions
Thanks
Rich -
DD14, My 03 12.7 has the small turbo, and I have been told a bigger turbo will cause less back pressure. ??? Could you suggest Make/model? I have allready put on no-baffle muffler, checked charge air cooler, run rack. This week-end the restrictor fitting and mechanicle fuel pressure gauge. Thanks.
Dave
