Wanting to buy a truck to do loads for the mountains (EX Colorado/California areas)
Discussion in 'Questions From New Drivers' started by WKingD, Sep 9, 2017.
  1. WKingD
    WKingD Bobtail Member
    Looking to buy a truck to do mountain loads, which truck or engine is recommended? I am asking bc a friend of mine has had their truck broken down 3 times in the last month trying to make successful loads from there.
  3. 201
    201 Road Train Member
    12,321
    25,187
    Apr 16, 2014
    high plains colorado
    The biggest darn motor you can get, my friend.:thumbup: Pretty hard to kill a series 60 Detroit., no less than 500hp.
    TripleSix Thanks this.
  4. DUNE-T
    DUNE-T Road Train Member
    6,944
    16,849
    May 10, 2015
    Detroit, MI
    Cummins N14 525hp with 18sp. Hard to find them though
  5. Scottyboy
    Scottyboy Light Load Member
    Aint no mountain high enough to hurt a CAT.
    Get ya something w/a 18spd for sure-so you have control.
    As stated above-no less then 500 ponies.
  6. TripleSix
    129,753
    500HP and 3.70 gears and a 13 speed minimum for 80000lbs. More than 80000, go with 3.90 gears and 525-550HP and an 18 speed. The truck will be strong enough to change the rotation of the earth.
    Jilani and 201 Thank this.
  7. Ridgeline
    22,386
    116,293
    wow you guys, really setting him up for failure.
    To the OP, learn from your friend, don't buy a truck unless you know how to buy one. Most don't and most break down and get in over their head with money.
    There is a process, go look up here dyno test on this site and you will find a lot of posts with the info you need.
  8. loudtom
    loudtom Road Train Member
    1,717
    2,801
    Aug 26, 2016
    I use a 550 hp D16 Volvo 780 with 3.08 rears and a 12 speed I-shift. I pull the mountains west of Denver often and have no trouble.
