Warn Engine. Engine shutting off
Discussion in 'International Forum' started by redcentury07, Jun 25, 2014.
  1. redcentury07
    redcentury07 Light Load Member
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    Hi, well i changed my oil pressure sensor since the mechanic said that is the only problem. I went on one trip and on the way back, i filled up Diesel at a small Truck stop. After 40 miles the warn engine light turned on during up hills and my engine would shut down. It happend ever 10 miles until I got back. The mechanic plugged it to the computer and cannot find out a single issue. He says its from excessive idiling and taking light loads?? Please someone help. I changed the fuel filters and still nothing
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Does the oil pressure read good? Are your fluid levels good? The light coming on uphill sounds like your oil level is low or the oil pump is bad but you should see that on the gauge with the needle dropping to zero.
    I understand the need to get home but you really shouldn't override a engine multiple times that is shutting down. Overriding is just to get off the highway. If it was a real problem instead of electrical you could be buying a new engine. That's a very expensive chance.
    He doesn't sound like a mechanic. That's nonsense.
  4. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    I would check the oil level. I would also check the oil pressure. If the oil is low, then add up to full. If your pressure is lower than normal, then change your oil. You might have a partially clogged oil filter. If that isn't the problem then I would take it to someone who can connect to your cpm. If that doesn't show any problems, I would look for a wire that could be shorting out. It doesn't take much to short out wire.
  5. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    What is the actual code it is logging? What engine and model of truck is this?
  6. redcentury07
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    Its a 09 Isx435 HP. dont have model #. Today we did a full regen 45 minutes and it ran well for 35 miles til it arrived to the mechanic. Mechanic said there was no active codes but there was smoke when he opened the oil cap and said it was starving for fuel. I have only done 1 trip since i purchased the truck. He said it was burning some oil.
    77fib77 Thanks this.
  7. roadglide547
    roadglide547 Bobtail Member
    8
    Also check the coolant level , some of them have a coolant level sensor as the fluid moves away from the sensor it can cause issues , it usually throws a code though
  8. Heavyd
    7,752
    6,185
    Feb 4, 2009
    If it isn't logging any codes I would say the engine is losing ignition power.
  9. 77fib77
    77fib77 Road Train Member
    10,190
    62,964
    Jul 7, 2010
    St Louis
    Double check antifreeze level.
  10. raul_cont
    raul_cont Bobtail Member
    Hello, I've got a 2014 international prostar Cummins isx and the engine is shutting off and blowing smoke, if the driver opens the key the temperature starts going up and on the dash it shows a message saying ABS mode and warn engine with a yellow triangle on
  11. Heavyd
    7,752
    6,185
    Feb 4, 2009
    These are signs the engine ecm is shutting down with the key on still.
