Water in oil, sample showing .54%, should I be concerned?
Discussion in 'Ask An Owner Operator' started by Tracker t, Apr 26, 2019.
  1. Tracker t
    Tracker t Bobtail Member
    Just got my oil sample back showing .54% water in my 06 ISX, should I be concerned about a head gasket? All other wear metals showed ok
  3. AModelCat
    159,767
    Just water? No glycols or silicates? If its just water its likely not a head gasket or anything like that. More likely just crankcase vapours or maybe you had a bit of water leak in from an engine wash or something.
  4. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Change your oil, and sample again in about 10,000 miles.
    That may help solve this.
    Replace 1 gallon oil with 80/90wt gear lube, it's an what ISX fans do.
    Because Lucas is useless.
  5. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    The only problem with putting gear oil in the motor oil is it can cause the oil to foam them lose oil press.
  6. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    It's been done by many ISX experts.
  7. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Actually I think it's only thing Lucas is good for. It's 50W oil but not much else. I can never figure out why guy's use it on perfectly healthy motor.
    bzinger Thanks this.
  8. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Lucas is not a high pressure lubricant.
    Gear oil is. ISX the Dual cam ones like to spit cams. Because of many reasons. Cummins is also a low pressure oil system.
  9. 77fib77
    77fib77 Road Train Member
    10,670
    67,358
    Jul 7, 2010
    St Louis
    Roll the berings. (No I don't think it will help).
  10. Westdude
    Westdude Bobtail Member
    10
    20
    Mar 7, 2019
    .54% water is not too much.
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Who is these experts, that are using gear oil?? Is that a Cummins recommendation?
    AModelCat Thanks this.
