Water in the truck?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Tb0n3, May 8, 2021.
  1. Tb0n3
    Tb0n3 Road Train Member
    4,379
    8,573
    Oct 5, 2012
    Earth
    I've had this in mind for the truck for quite some time. I had two uses for it initially but it's expanded.
    With a setup like this, and maybe a larger tank, I can wash dishes or my hands, but I can also use the supply to more easily brush my teeth. The initial idea was to have a one handed method for filling a cup with water. That way I can keep going but also have a method to easily make flavored drinks with MIO and other such products.
    Has anybody else made themselves a truck sink for their own use? Something that doesn't necessarily require huge modifications to the company truck would be great for inspiration.
  3. Arctic_fox
    3,975
    20,484
    Sep 16, 2016
    I had a simular setup to this for years in the oilfield. Used a 5 gallon metal jerry can though in mine and a battery powered pump. Pump died and i just never replaced my system. Was pretty nice though. One thing to note is use a metal "sink". I just used an old industrial buffet tray. Plastic ALWAYS starts to meldew after a few weeks.
    buddyd157 and NavigatorWife Thank this.
  4. Tb0n3
    4,379
    8,573
    Oct 5, 2012
    Earth
    Certainly anything will mildew if it isn't cleaned. It may discolor though and get brittle depending on the quality of the plastic.
    I do like the buffet tray idea though. That sounds perfect and durable. I was considering a grey water tank, but I'm not sure if dishwater or hand washing water is any worse than piss in a truck lot.
  5. Arctic_fox
    3,975
    20,484
    Sep 16, 2016
    Honestly considering what ive seen in those lots.....its likely an improvment. As for mold, true but my problem was i was always working with crude so it would trap stuff in pockets in the plastic no matter how often i wiped it down or rinsed it and would grow mold after a few weeks.
    May not be as bad for you though. Plus you can use a magnet to stick the pan out of the way. I used to mag it to the bottom of my bunk.
  6. Rideandrepair
    17,258
    56,006
    Aug 8, 2015
    I’ve been wanting to do something like that for years. My thoughts were a large tank, in the shelf above the sink. SS bar sink, plastic faucet, drain out bottom of Truck. I doubt a drain trap is needed. Unless a bug flew in, Lol. No pump, just gravity fed for simplicity. Pressure would be better of course when tank was full, dropping as tank emptied. Tank could be filled with gallons drinking water, for making coffee, brushing teeth, washing hands. Now my wife and I typically leave out with 10 gallons of water. They’re in the way most of the time. Mold would only be an issue, if not used for extended time. A tiny amount of bleach would take care of that, flushing it out, before using again.
  7. MidWest_MacDaddy
    11,105
    18,586
    Feb 21, 2015
    South Carolina
    Interesting concept… I currently use a 5 gallon carboy with a Prima battery pump to pump fresh water for my morning coffee or flavored drinks… but something like this would be an improvement if I can control it from the handset vs button on top of the pump setting atop the carboy.
    My current setup works for moms for now, but ya, I might have to do some thinking on the next steps.
    Thanks for posting it.
    Rideandrepair Thanks this.
  8. Rideandrepair
    17,258
    56,006
    Aug 8, 2015
    The hand spray is handy for making coffee. Been using it at home for years. Be nice in the Truck. Even a fixed sticker above coffee pot would be handy. Using gravity only.
  9. Tb0n3
    4,379
    8,573
    Oct 5, 2012
    Earth
    One thing I've wanted since day one is a lever dispenser for water like you have on a soda fountain. Doesn't need to be fancy with electric actuators, just a press valve to fill a cup. It seems that either they're not made in standalone to mount somewhere or my google-## is weak.
    Hmmmm, do they censor kung-##?
  10. Rideandrepair
    17,258
    56,006
    Aug 8, 2015
    My Uncle has a water cooler dispenser in his Shop. Refills the bottle. Something like that maybe. Bottle would need to be secured of course. That’s all I’d need. Placed directly over my coffee pot. Maybe a bar sink with an insert top on it. Set the coffee pot on top. Moving it over, to use sink. I see the big bottles of drinking water at Wal mart.
    Brettj3876 Thanks this.
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    You've got plenty of room in that 84in bunk. Couple of months i drove my uncle's classic that felt like a house compared to my 60in mid Lol
