water level warning
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Sep 14, 2017.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    97 freightliner, detroit engine. today a red light on dash lit up. ''water level'' I checked resivour it was full. unplugged sensor in resivour and straight wired pigtail, all that did was give me a ' check engine light. replace sensor ? or look for another cause for light coming on ?
  3. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    I had this same problem and it ended up being sensor in the tank.
    heavyhaulerss Thanks this.
  4. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    its the sensor,and i believe you cannot just bypass the sensor by connecting or disconnecting the wires to it.
  5. luckystar
    luckystar Light Load Member
    113
    143
    Aug 1, 2017
    I was having the same problem with a 1995 Kenworth t600 with a 12.7 Detroit engine the water level and the check engine light were coming on so I just disconnected the wire from the sensor. The water temp gages are showing fine so I will be replacing the sensor soon
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Sensor or wiring right at the sensor plug are the 2 most common failures. Grab each wire and give it a good tug at the plug. If the wires are broken internally they'll pull apart, get harness repair end.
    heavyhaulerss and SAR Thank this.
  7. xsetra
    xsetra Road Train Member
    5,182
    7,123
    Aug 21, 2011
  8. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    In my T660 there's a magnetic float in the tank. The sensor is in the shape of a rod and snaps into a tube that's actually the same tube that the magnetic float inside the tank floats up and down on.
    Pull the sensor rod and touch the tip of it with a magnet, if the light goes off then it's not the sensor but the float instead.
    I couldn't get it to float so I had to replace the whole coolant tank.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Turned out to be the pigtail that plugged into the sensor. Tried sensor first. $27.00 at freightliner for the pigtail. $46.00 for the sensor.
    SAR and GrapeApe Thank this.
  10. xsetra
    5,182
    7,123
    Aug 21, 2011
    I bought 2 and then a week later bought the whole sensor and injector harness.
    Just thought if the ends are going bad. I didn't want to be stuck with stop engine light beside the road in some mountain pass or worse downtown Chicago during rush hour.
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Well i thought I had my low Water level light problem fixed. It stayed out for a hour then back on again. any suggestions? Thinking it's a ground issue. Where to look? Followed the sensor wires thru the air loom, all looks good.
