Water Pump Weep Hole CAT 3406e 1lw
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by subtex, Jan 30, 2019.
  1. subtex
    subtex Bobtail Member
    Dec 4, 2018
    Where does one find the weep hole on the water pump? I have coolant in my oil and the local shop thinks it’s the water pump. The Cat # is 135 4918. Do these pumps leak internally? Any help would be appreciated! Thanks
    Rideandrepair Thanks this.
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    I am not sure about the 3406, but I had several C-12's and they all leaked internally when the pump seal failed.
    Rideandrepair and subtex Thank this.
  4. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    I believe all cat water pumps are close to same design but not 100 percent sure. I just changed mine out on my c12. I couldn’t even find my weep hole. The hole was plugged up with debri and sludge when I removed it. The new water pump from cat came with an information sheet on the pump and said that the “weephole will possibly drip from time to time and was designed to do as such” it gave more info on why. It went on to explain that if it leaves a puddle then there is a problem. Cat also left an instruction sheet on how to refill the system to ensure no air pockets
  5. subtex
    Dec 4, 2018
    Ok, just trying stay away from throwing parts at it. Would hate to put a new water pump on and then realize that it’s liner o-rings. I have a 3406b and a C-15 Acert and both of those engines have a external weep holes.
  6. AModelCat
    159,615
    Unfortunately unless you open up the engine a bit you will just be tossing parts at it.
    Are you getting oil in the coolant at all? If not, I'd lean away from the oil cooler since oil pressure is greater than coolant pressure. The spots I'd suspect most would be pitted liners, liner seals, water pump, possibly a head/headgasket issue.
    Rideandrepair, subtex and Cam Roberts Thank this.
  7. subtex
    Dec 4, 2018
    No oil in the coolant that I can see, and doesn’t smoke white when running so I’m assuming it’s not the oil cooler or head gasket. In the morning I’m gonna pull the pan and do a coolant pressure test to see if any liners are bad.
  8. Rideandrepair
    17,349
    56,291
    Aug 8, 2015
    If there is a weep hole. It will be on the very bottom centered pretty much, will probably have a piece of foam in the hole acting as a catch, to absorb minor weeping. Originally they all had them. Don’t know about possible upgraded type you have.
    starmac and Cam Roberts Thank this.
  9. Rideandrepair
    17,349
    56,291
    Aug 8, 2015
    It’s about 3/4” round
    starmac Thanks this.
  10. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Maybe that’s what was in mine. The new one is at very bottom like you said with a clear through hole
  11. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Yes water pump will leak into oil.
    Not all 3406 C15nz are the same.
    I did this last year
