Water Sealant for dry van wood floor
Discussion in 'Ask An Owner Operator' started by firecatf7333, Jul 17, 2017.
  1. firecatf7333
    firecatf7333 Light Load Member
    175
    59
    Oct 28, 2012
    2001 utility and sometimes when I drive in the rain the floor will get damp and you can see the wood floor turn darker.. Eventually this is gunna cost me a load.
    What kind of sealer could I put down on the floor? Clear Epoxy? I'd like to get a few more years out of the trailer.
    I also thought about painting the floor black..which then I dont think you'd be able to notice the floor having some moisture.
    Thanks
  3. buddyd157
    buddyd157 Road Train Member
    13,513
    34,629
    May 25, 2017
    under a shade tree
    you could use epoxy, but you may also have to do the underside since this is where the moisture is coming from. you'd have to pressure wash the bottom, allow to dry a few days, then epoxy. full coverage of the wood is better than half a job.
    Grubby, TallJoe and DoneYourWay Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,430
    6,466
    Aug 26, 2014
    I would be more concerned about sealing the bottom. Maybe pressure wash it, put a heater under it for drying and under coat it. My car dealership freind would probably spray it right outside the door on a Saturday morning.
    I normally only had to worry getting out of town company trailers loaded that had been rejected. Only worked from the top. Common leak spots are open gaps in boards, lower rails pushed away from the floor and between the steel floor plate and wood. It only takes a small opening in the right spot for the drives to put a lot of water in the trailer. Look for light inside with the doors closed but that is not 100%.
    buddyd157 and Grubby Thank this.
  5. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    What's that stuff they used to advertise? Oh yeah..."Thompson's Water Seal? $30 a gallon?
