Water temp help
Discussion in 'Ask An Owner Operator' started by Mohtrucker, Jan 13, 2021.
  1. Mohtrucker
    Mohtrucker Light Load Member
    135
    188
    Oct 20, 2019
    I have a 05 Columbia with a series 60 engine when I’m at highway speeds my water temp gauge goes down to 100 degrees but when sitting idling it will go to above 150. My ac/heater will stop working also but works fine when idling, appreciate any advice I don’t want to pay someone money if it could be solved by changing a sensor or fuse
    6wheeler Thanks this.
  3. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
  4. Spyro2112
    604
    416
    Mar 17, 2018
  5. thaistick
    thaistick Road Train Member
    1,416
    1,737
    Dec 7, 2014
    OTR/Thailand
    Second for the thermostats!!!
    jsnell and DieselDisciple Thank this.
  6. Spyro2112
    604
    416
    Mar 17, 2018
    Might think about new fluid, radiator,, detroit radiator. Michigan
  7. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    My guess the thermostat stuck open, coolant goes through rad all the time. When you move at highway speed the airflow passing through rad is overcooling the coolant, when stopped even if the thermostat stays open without airflow temp goes higher. I read that are designed if breaks to fail open, is less damaging won't cause overheating. But if the thermostat is stuck open , engine oil temp drops and moisture won't evaporate can mix with oil causing sludge and for newer engines with DPF low eng temp causes regen problems.
  8. Spyro2112
    604
    416
    Mar 17, 2018
  9. Ridgeline
    22,457
    117,695
    It isn’t anything but the thermostat. One is bad and stuck open.
    lester and Mohtrucker Thank this.
  10. snowwy
    snowwy Road Train Member
    20,568
    13,293
    Jul 6, 2009
    Thermostat is what controls the water temp.
  11. Spyro2112
    604
    416
    Mar 17, 2018
    Thermostat opens and closes to cool the engine. Fan turns on
