WD-40 for landing gear
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dztruck, Dec 28, 2020.
  1. dztruck
    dztruck Light Load Member
    271
    208
    Feb 22, 2017
    Anyone ever use wd-40 for their landing gear? My landing gear seems pretty heavy right now. Would that be a quick fix, i gotta do a lot of drop/disconnects this week.
  3. Numb
    Numb Crusty Curmudgeon
    4,085
    9,423
    Jan 30, 2012
    Charlotte, N.Carolina
    grease is probably ,( or is it "prolly" now?), cold. grease gets thick when cold
  4. Rideandrepair
    17,344
    56,270
    Aug 8, 2015
    That old grease needs to be cleaned out. Without taking it all apart, might try some slick 50 grease.
    dztruck Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,033
    Jul 12, 2017
    If you think the tubes are dry and binding, extend them all the way out as far as your can when empty. Wire wheel the legs and apply a thin coat of grease all around the leg the full length. The grease will go into the joint instead of running down with gravity. Of course lube the normal zerks at the gear boxes.
    The greased gears always turn slight harder in the cold.
  6. 062
    062 Road Train Member
    6,222
    33,477
    Oct 20, 2013
    I prefer fluid film on the legs. Wd40 has a knockoff called gel lube,it’s not bad but does wash off.
    dztruck, 650cat425 and Goodysnap Thank this.
  7. beastr123
    beastr123 Road Train Member
    2,864
    23,507
    Jan 2, 2014
    Moose Jaw SK CAN
    Take the tops off the legs and add 4 to 6oz 75/90 synthetic gear lube preferably when the legs are extended. Then open the gearbox and remove the extra grease in there and close it back up and add some 75/90 to it either by a rubber plug that is on some or by putting it in a 1/2 emptied grease gun and putting it in through the zerks. Then run the legs up and down 4 or 5 times to mix the grease and oil. This was a way to "winterize" landing gear when running to the mines of Northern Saskatchewan that worked well.
    BoxCarKidd, Flint1, AModelCat and 5 others Thank this.
  8. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Get the water out of the gears by draining the gearbox. I have used antifreeze sprayed on the legs for lubrication in cold weather.
  9. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    Yeah WD - 40 works we'd used all sorts of stuff to improvise including some diesel, grease anything to keep things free and lubricated, the extreme cold don't help much either.
