Weak brakes on the drive axle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by olpa77, Apr 26, 2012.
  1. olpa77
    olpa77 Light Load Member
    72
    15
    Apr 9, 2011
    I have been having a problem with my drive axle brakes not working correctly. I have a 96 freightliner fld 120 without abs. It seems like my trailer and steer axle brakes are doing all the stopping. The drums on the trailer and steer axles are running hot while my drives will be just warm. Every thing is in adjustment. I have been in the shop 4 times and replaced many valves (foot, mv-3, and proportioning valve). The brake chambers were replaced a little over a year ago. "S"cam and bushings are good. Pads are about 60%. I am really stumped here, anyone have any ideas? :biggrin_25511:
  3. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    I had one doing this and the foot valve was leaking air, so it was a no brainer to replace it, but still had lack of stopping power from the drives. I then replaced the drive axle service relay and BINGO! Stopped like a Champ!
    You could check applied air pressure to your service brake chambers rather than just replacing the valve, but due to the price of a service relay and labor I'm not sure that would be cost effective.
  4. itchygomey
    itchygomey Bobtail Member
    15
    10
    Mar 12, 2012
    Try backing the steers and the trailer way off. Then apply about 15lbs. The only shoes working will be the drives. This will tell you if it's a problem applying pressure or if the shoes just aren't doing the job. I know it's a long shot, but ya never know. Hate to overlook the obvious!
    canadianrebel Thanks this.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    do you have LSV? old trucks w/o ABS had LSV valves
    olpa77 Thanks this.
  6. olpa77
    72
    15
    Apr 9, 2011
    Not sure if it has an LSV or not, but if older trucks had them I bet mine does too. Any idea where it would be located at? Freightliner told me there is a valve on it that cuts braking effort to the drives when bobtailing. They said when I push in the trailer brake valve on the dash the valve should then return normal braking effort to the drives. They replaced that and it did not correct the problem. Also the valve bender is talking about what does it control and where would it be located at?
    I have very little knowledge about the air brake system. I never knew there could be so many relays and valves. When it comes to the air brake system I always take it to a shop. However I have spent $1500 in the shop and the problem has yet to be corrected!
  7. bender
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    LSV or load sensing valve is the the one Freightliner is referring to. I don't know the location of that valve. The service relay should be on the frame rail back by the drive axles. The service relay valve sends air directly to the service side brake chambers.
  8. bender
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    Was the proportioning valve that was replaced at the front of the truck for the steering axle?
  9. olpa77
    72
    15
    Apr 9, 2011
    The proportioning valve was right in front of the fifth wheel. It is the valve that freightliner replaced. It is also the valve they said controled the braking effort while bobtailng.
  10. bender
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    OK, that's what Pablo was calling the LSV. All you have left is the service relay valve, unless someone misadjusted your drive axle brakes.
    olpa77 Thanks this.
  11. olpa77
    72
    15
    Apr 9, 2011
    I'll recheck adjustment and try replacing that vavle and let ya know. Thanks.
    bender Thanks this.
