Webasto Air Top 5000 installation.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pablo-UA, Sep 13, 2011.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    The winter is coming!!!! Yep, it is september only, but winter is soon, so I got cab heater. It was bad, so I got it free!!! YEAH!!!
    It is AT5000. I made a remote controll tor it and got glow plug fault code. The problem was in MOSFET switch inside control unit. I fixed it easily and did test start on bench.
    Ok, now I wanna fit this monster in Century Class ST cab. So any tips gentelmen.
    Ouh! I wanna install separate tank for cab heater, becouse when it is really cold diesel fuel is like a gel and we use to fill cab heater tank with aircraft jet fuel and add some (up to 30%) of jet fuel in diesel fuel.
  3. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    P/S, to diagnose it I used Mercedes Star Diagnose, but today I assemblied ISO K-L adapter and used Webasto TermoTest software, avilable free on Webasto Web Site
    SHC and VisionLogistics Thank this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Sounds like you got it all figured out. You dont need us
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    well, the quation is what is the optimal point of installation? I wann install it in right hand sleeper box but I need to get intake air somewhre in cab but avoid heated air and intake mixing
  6. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    The normal place is under your lower bunk. intake to one side, exhaust to the other.
    Cascadia's has it in the desk area with a chmney exhaust comming out at the top bunk (working vertically)
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what park heater is used on Cascadia? AT2000ST ore Eber D3LC?
  8. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I have the AT2000ST and my intake is to the side of the cab and the exhaust is to the rear. You do not want to pull your INTAKE air from INSIDE the cab, in fact it explicitly states it in the instructions.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    You say about air intake of combustion chamber, I say about air to heat intake, 3" hole with grill, inside cab. Heated air outlet is 3" too, but no grill.
    about 1" air intake to burn fuel and 1" exaust... yep, I will do all the way you say
  10. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Yeah, i thought you were talking about the other way.
    I have mine under the pass side bunk as well. It pulls plenty of air from inside the compartment and I do not have it routed or duct'd any special way.
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Aha, like on DAF and MAN trucks. Mercedes install it on early trucks hidden by driver's seat, on newer - in box, outdoor.
    I wanna install under lower bunk.
    What the truck do you have? mine is Century Class S/T
