Hello any suggestions my Webasto Heater on my 09 Prostar International blows cold air more often than hot air and if I let it run for a while to see what it does a green triangler indicator light starts to flash on the front of the operational knob, also my Air Horn isn't working any assistance would be great.
Webasto heater blows cold air and air horn not work 09 prostar
Discussion in 'International Forum' started by no love for a trucker, Feb 12, 2014.
Page 1 of 4
Horn broken? Use middle finger!
My wabasto bunk heater wasn't putting out hot, turned out my air inlet was blocked. Mine draws air from inside the cab as it is a factory wabasto and I was putting my bag in front of it. That would be the first thing I would check.
KB3MMX Thanks this. -
thanx will check and see also i forgot to add this particular unit has 1 operational knob that functions everything it has a green triangle on it that is flashing after a period any idea on what that means i just purchase an manual but it speaks nothing about the Webasto Heater.
Thanx Again
DustinBrock -
Cant help you with your heater. Might check the heater hoses and see if the valves are on? Try removing and throughly washing out your air hornes. You will find they are full of bugs and dirt. Put them back and they should work fine. Assuming that they are getting air supply to them. Good Luck...
10-4 again for the help
Kenan S. any idea on the location of horn?
HaHa, Not a clue... I have 379's and has been a long time since I've even been in another truck other than to visit. I can tell you that calling the dealer or just doing a search online may reveil a clue or more. If worse comes to worse, just trace the air line that is on the other in of the valve that you pull. I'd google it first though.......
Google the Wobasto manual, I have an Espar but the manual is easily found online.
I had a similar problem with my Espar last year, it turned out that the heater had sucked in enough lint and dust to short out the overtemp sensor and would shut down. I removed the intake grate then used my airseat blowgun blowing through the cold air intake and clearing the sensor off...maybe Wobasto has this happen too.KB3MMX and no love for a trucker Thank this. -
Heavy Load Member
If I was still an ignorant and worldly man I would have probably responded to you in such a manner, that it would anger you and you would probably, invite me to meet you anytime any place anywhere and with my use to be ignorant self I would. Just to prove a point to a 27 year veteran truck driver know it all. But I'm not that same person, so rittle me this 27 year truck driver veteran.
Question:
What are worthless and wicked people like?
Answer:
They are constant liars, signaling there deceit with a wink of the eye,
a nudge of the foot, or the wiggle of fingers.
There perverted hearts plot evil, and they constantly stur up trouble.
But they will be destroyed suddenly, broken in an instant beyond healing.
You just keep on truck 27 year veteran I guarantee GOD will touch the heart of a true GOD fearing person on here and help me get the answers I seek have a BLESSED rest of your life.
Lesson for today from a 5 year veteran to a 27 year veteran HUMBLISISM no one on this planet knows everything. Even you 27 year veteran had to be taught, what good are you on here if you are not trying to help others. Humble yourself and Thank God for all HE has provided you with. I will PRAY for you 27 year veteran.Last edited: Feb 13, 2014
x1Heavy Thanks this.
Page 1 of 4
