Webasto heater blows cold air and air horn not work 09 prostar
Discussion in 'International Forum' started by no love for a trucker, Feb 12, 2014.
  1. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Depending on how many hours is on the heater, you might want to consider some or all of the following: The fuel line has a screen/filter in it, which should be replaced if it has not been for a year or 2, the glow plug and screen inside of the unit itself can get crudded up and will limit the output, last and most expensive the firebox itself will wear out. My firebox lasted 7 winters, dealer said they have replaced them as short as 3 years. Lots of smoke on start up is usually a sign of glow plug, internal screen, or firebox problems.
    KB3MMX and no love for a trucker Thank this.
  3. mrtrdrvr
    mrtrdrvr Light Load Member
    154
    35
    Nov 6, 2009
    Indian River ,MI
    ok, you have to count the flashes on that green triangle. it will flash 5 times quickly then give you the fault code in long flashes. count the long flashes and post here.
    no love for a trucker Thanks this.
  4. no love for a trucker
    no love for a trucker Light Load Member
    93
    26
    Jul 28, 2013
    Greensboro, North Carolina
    For all those with a Webasto Airtop 2000ST manufactured in 2008 heres a number you can call to the Webasto Tech Center 800-555-4518 opt# 2 they are very will to assist you and here's a direct link to the manual for both diesel and gas models: Airtop_2000ST_vedlikeholdsmanual_engelsk.pdf .
  5. Heavyd
    Heavyd Road Train Member
    7,780
    6,218
    Feb 4, 2009
    You will probably find your Webasto is flashing 5 times, then 1. The quick 5 flashes is not the code, just a space in between. If it is flashing code 1, this is very common. It means no combustion detected. Very common for these to have burners that are all gunked up inside and eventually will not fire. Most effective repair is to replace complete burner unit which comes as a kit.
    Your horn is actually rather complicated. The air horn button on the steering wheel sends a signal to the body controller. The body controller sends 12volts to an air solenoid which allows air to the air horn. The solenoid is located on the left frame rail near the transmission. The horn is located under the front bumper area on the drivers side.
  6. no love for a trucker
    93
    26
    Jul 28, 2013
    Heavy D when I hit the button on the steering wheel I do hear a clicking sound with that being said does that help with the process of elimination the horn seems to be intact and ok i tried to check the lines to see if there's a leak of any kind. Your assistance is deeply appreciated and im grateful aswell im due a DOT inspection in March Im trying to get ready.
  7. no love for a trucker
    93
    26
    Jul 28, 2013
    or i should say a slight air sound like its being released but isn't getting to its destination.
  8. Heavyd
    7,780
    6,218
    Feb 4, 2009
    Try popping the air line out of the horn itself. It is just a quick connect fitting. At the end of the fitting where the line goes in, you will see a little collar. This collar is what locks the air line into the fitting. If you press the collar into the fitting while pulling out on the line, the line should come out of the fitting. Then press your horn button and see if you can hear air hissing from the open air line. The reed valve, or whatever it is, in the horn may be broken or plugged. If no air, I would say the air solenoid is buggered on the frame rail. The air horn solenoid will be mounted in series with other solenoids such as, 5th wheel slide, air suspension dump and possibly power divider lock. If those devices work, your air supply to the manifold is ok.
  9. no love for a trucker
    93
    26
    Jul 28, 2013
    yeah i did see that earlier when i went under the front ok i will do thanx will keep you posted and GOD bless you.
    Heavyd Thanks this.
  10. beastr123
    beastr123 Road Train Member
    2,872
    23,580
    Jan 2, 2014
    Moose Jaw SK CAN
  11. no love for a trucker
    93
    26
    Jul 28, 2013
    This is a follow up for the webasto heater I took it into a webasto location for a service $115 and as for the air horn. I disconnected the air line from the air horn on my truck. My truck has to be running for the air to be supplied to air hI THINK this is due to air solenoid. I had someone pushing the air horn button to insure the air supply was working and it was as the driver pushed the air horn button air could be heard and felt being released. I took the air horn apart and saw the thin plate on the inside was dried shut due to moisture and debris getting into it through the mouth of the horn. I cleaned the back and front of the thin plate on the inside really good and put air horn back together reconnected the air line and whalla all better people. I hope this helps.
    Heavyd Thanks this.
