webasto heater (odor/smell)
Discussion in 'Experienced Truckers' Advice' started by kikobug, Oct 11, 2014.
  1. kikobug
    kikobug Bobtail Member
    11
    4
    Oct 1, 2014
    I picked up my new volvo which comes with a webasto bunk heater. I turned it on and there was a odor i couldnt exactly pin to what it was. I did some research and found several people talking about exhaust leaks,fuel leaks, carbon monoxide etc. In my situation this was not the case, turns out it was more like a plastic/rubber new smell but strong enough for me to research it. So if this is helpfull to anyone in my same situation, if your heater has been sitting for several months or is new i suggest turn it on HI full heat and full fan speed for 45 min to an hour with the windows open to vent out the smell, let it run its course and allow it to blow it all out and after that should be good.That is what i did and it worked for me.
  3. freightwipper
    freightwipper Road Train Member
    9,366
    11,439
    Mar 24, 2014
    OTR
    yeah man idk what the F that smell is, I think mine is exhaust leaks.
    can't be too healthy but then again neither is being a truck driver so screw it haha
  4. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    If the heater isn't used for an extended period, dust will build up on it and cause the odor that you described when it is first used. Just run it on high for a few minutes to get rid of the dust build-up. If it's used frequently after the initial use, that smell shouldn't occur again.
  5. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,301
    Nov 8, 2009
    The Highway To Hell.
    It's fine. Mine does it too. After a while it goes away, it's kinda like a new car smell, lol. After a little while it stops that. Nothing to worry about.
  6. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Go to Walmart and in the lamp section get a small bottle of kerosene. Get about 4' of rubber fuel line or any rubber hose from Home Depot. Pull the line off the fuel pump and put the other hose on to the bottle on the ground. Run heater full blast until it's all gone. Kerosene burns much hotter then diesel and will clean it out.
  7. Oldman49
    Oldman49 Medium Load Member
    353
    300
    Jul 20, 2014
    Remember to keep the supply vent clear. My plastic bucket had a hole almost melted thru,,,might have scorched a blanket too,,,,would like to think nothing would ignite,,hot little jet engine is what it is,,,,( espar )
  8. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    If the vent is faced down towards the floor or blowing against anything rubber and it's on high heat you will get a rubber smell
