weekend in Gary yard
Discussion in 'Maverick' started by saltwaterm, Jul 20, 2014.
  1. saltwaterm
    saltwaterm Bobtail Member
    9
    May 13, 2014
    Forney, TX
    I am a new driver. Im in Gary for the weekend.
    How long should I idle my truck to charges the batteries?
    Thanks
  3. buzzarddriver
    3,576
    10,306
    Feb 1, 2011
    Dallas, TX
    That all depends on the load you are putting on the batteries while sitting there.
    If you don't have an APU and are watching a TV or using a computer, have a 12v cooler, or other such load, then 30 minutes for each 3 hrs would be enough. If you are not using any appliances, then you wouldn't need to idle to charge the batteries at all.
  4. saltwaterm
    9
    May 13, 2014
    Forney, TX
    Yes I have an APU. I was in the yard with A/C going most of the night. I have a 12v cooler and run the A/C at times. All so have microwave no tv.
  5. buzzarddriver
    3,576
    10,306
    Feb 1, 2011
    Dallas, TX
    Well, your APU should charge the batteries, so there would be no reason to run the main engine. I am assuming you were running the A/C from the APU.
  6. saltwaterm
    9
    May 13, 2014
    Forney, TX
    Yes I just want to make sure it will start at the end of the day.
  7. projump
    projump Light Load Member
    287
    61
    Jan 24, 2012
    Southeast Missouri
    Maverick trucks have EPU units (electric power units) to run the bunk heat, AC, plug ins etc. powered by 4 batteries. There are 4 separate batteries for the truck, so the engine starting won't be affected if the EPU batteries get low. When the EPU batteries get low there will be a beeping sound and the lights in the bunk won't work. I've been informed to idle for about 2 hours (cruise on, hit accel to bump idle to 900 rpms) to fully recharge the batteries.
  8. plentygood
    plentygood Road Train Member
    1,108
    729
    Apr 24, 2011
    USA / CANADA
    Hey saltwaterm, do me a favor and run up to Zantes and Fed-X me a Gyro!
  9. Rigbuilder
    Rigbuilder Medium Load Member
    335
    103
    Jun 17, 2013
    Bedford, Texas
    There are plugs at Gary that you can use. (Or there were the last time I was there) on the backside of the shop near the fence. Get yourself an extension cord and plug in. No need to idle.
