Weigh Station Brake Check or Brake Activation?
Discussion in 'Questions From New Drivers' started by GAShog19, Mar 20, 2023.
  1. GAShog19
    GAShog19 Bobtail Member
    41
    13
    Dec 28, 2022
    Englewood, Oh
    on the newer trucks (or older for that matter) when you are coming up on a weigh station and you go under that bar that has the funky looking camera thing - does it "brake check" you - this truck has never done anything like this up till then and hasn't again ... but when I went under that bar it like slammed on the brakes ... it didn't lock them up but warnings came on the dash but all the gauges looked good air wise
  3. keebler13579
    keebler13579 Heavy Load Member
    947
    1,860
    Nov 16, 2012
    Your sensors were reading something in your path falsely. Have had it happen to me a couple of times
  4. Numb
    Numb Crusty Curmudgeon
    4,055
    9,314
    Jan 30, 2012
    Charlotte, N.Carolina
    gotta love the auto-brakes.
    must be nice on a snowy day.
    maybe that's how a lot of these pileups happen?
  5. LTLTRUCKDRIVER
    LTLTRUCKDRIVER Light Load Member
    164
    300
    Jun 3, 2019
    Immediate Collision .... that's your forward-looking sensors make sure you turn off you cruise.
  6. wis bang
    wis bang Road Train Member
    3,392
    3,990
    Jan 12, 2011
    Levittown, PA
    Brake system sensors are thermal and low level looking for the hot or cold wheel among all the warm [working] ones.
  7. tscottme
    tscottme Road Train Member
    My 2020 Freightliner used both the radar in the bumper and the forward-facing camera. If one or both saw something that suggested an impact it would activate the brakes hard.
  8. nredfor88
    nredfor88 Road Train Member
    1,801
    6,096
    Sep 26, 2019
    USA
    On the bridge going north on I57 crossing from MO into IL, each of the overhead beams would tap my brakes in my old truck, each and every one of them, so like a dozen or more times per crossing. That could be fun in bad weather, and if something happened the manufacturer wouldn't be at fault, the driver would.
  9. D.Tibbitt
    148,102
    Just wait til ur driving on a nice sunny day in the middle of nowhere, with Nobody or anything around and that auto brake puts you thru the windshield.. Useless invention.
    tscottme, Rubber duck kw, W923 and 6 others Thank this.
  10. Terlingua
    Terlingua Medium Load Member
    487
    1,019
    Oct 24, 2021
    I think it’s just coincidence that it happened to trigger at the weigh station. It happens from time to time. Sometimes mine will activate the brakes when I get a collision warning and sometimes it doesn’t. I haven’t figured out why it only brakes some of the time.
  11. Arctic_fox
    4,057
    21,075
    Sep 16, 2016
    And this right here is why i took mine off my truck. Had exactly that happen and it nearly caused a jack knife. Wide open road nothing for miles and my trucks radar with zero warning locked my wheels to the point i skidded and started to jack knife then as i started to correct it then released causeing me to overcorrect and did it again with me all over the bloody road trying to get control of the truck and the second time it never released the brakes. Turns out a little peice of gum wraper got stuck on the radar and it freaked the #### out. As soon as i removed it the brakes released from 100% application.
    Pete told me that was "normal". #### got disabled shortly after that.
