Weight Questions...
Discussion in 'Questions From New Drivers' started by Motoz13, Feb 24, 2012.
  1. Motoz13
    Motoz13 Bobtail Member
    10
    San Diego, CA
    I have a 3500 Dodge with a 40' flatbed..
    The trailer tag says 25,900 on it for a GVWR
    It has 3 dual axles. The tag says the axles are 8633 GAWR ea. the guy I bought it from said they were 12k axles...??
    My truck says 12,2 in the door jamb and 5200 GAWR Front and 9350 GAWR Rear..
    I am putting a flatbed on it and want to register it for it's max..
    Is that max 38,100 lbs? And does this combination give me a total payload capacity of 21,120 lbs since the truck and trailer scaled at 16980?
    Do I need a Class A to drive this setup if not commercial?
    If the axles are 12k axles, can the trailer be registered to carry 36k even if the sticker says 25,900?
    Thanks for your help.. Should I post this somewhere else?
  3. me only
    me only Medium Load Member
    309
    85
    Nov 9, 2011
    buford ga
    From what your saying .Its class a license ,anything over 26k lbs puts you into a different bracket .Im registered for 36k .with a 40 ft frailer ,puts me at 64 ft length 38ft bridge .
