Weird a.c. problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by double brew, Sep 19, 2017.
  1. double brew
    double brew Light Load Member
    76
    20
    Mar 7, 2015
    Well, I have a 99 p ete 379, and for a while, I was having a rare time where the a.c. would just randomly stop working. Over time, it got worse, till 2 weeks ago, it just didn't work. Made it home, threw a machine on it and it only had 2lbs, 6oz in the whole system. I put in a new orfice tube, accumulator, high pressure switch, and an expansion valve in the sleeper (never had rear air) Now, I know there has to be a leak beings it was that low, but here's the other situation. We sucked it down, left it under vacuum for 30 min, and it held. So, 5 lbs was added as the sticker shows, and it worked great for a day. Next day, it was hit or miss. No real rhyme or reason when it worked or not, but then, every time I'm parked with the fan on, it worked fine. It didn't work more than it worked, but we toughed it out for a few days, till today (from first recharge to today was 8 days). Went to a little shop in Iowa, looked over everything under a blacklight, and nothing was found. Sucked it down and it only sucked out 4lbs, 6 oz.
    Jumped the fan switch, and the low pressure switch and both worked. He was lost as to what to do, so he threw 5 lbs back in with more dye and off we went. It worked great the few blocks over to Petro for a quick shower, then we headed out. About 5 miles out of town, it quit again. So, I got ahold of peterbilt in cedar rapids, and they threw their machine on it. With idle at 1000 rpm, the low side was between 50-53 fluctuating with the fan. High side was 175-270ish. They thought it was a little on the low side, so they added another half a pound. Then, it dropped the low side to 37-41. Even then, the air out of the vents wasn't anywhere near as cold as it should be.
    They now sucked it down, it pulled out 5.59oz. So it didn't leak out. What's next. I'm so lost. They are gonna pump it up with nitrogen and try and find leaks.
    Any help?????
  3. double brew
    76
    20
    Mar 7, 2015
    Also, I should note, in the last year, the a.c. lines were flushed because my compressor took a crap. So, the system has a new condenser, compressor, oriface tube, accumulator, high pressure switch, and expansion valve.
    Also, the sleeper air stops working exactly when the dash air stops. So it's like something is shutting the compressor off.
  4. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    I have seen similar with a plugged evaporator, charge and pressure goes down. Clean evap and pressure will go up. But does soud like a leak anyways that needs chased down.
  5. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    Does the ac compressor still cycle on off when it stops?
    I think those pressure readings might be high?
  6. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Sounds like it's electrical. I'd be looking at the compressor clutch and wiring.
  7. Jace379
    Jace379 Light Load Member
    146
    97
    Mar 6, 2017
    Replace the relay for the a/c in the fuse box.
  8. AModelCat
    161,291
    Holding a vacuum ok isn't a 100% true indicator the system isn't leaking. Need to recover the refrigerant and pressurize the system with a few PSI of nitrogen. Sometimes they hold vacuum ok but leak under pressure.
    Just as a broad guess (not knowing the A/C specs) but the low side pressure seems a bit high. If you can't get the heat out of the condensor core, the low side will read high(er).
  9. Tug Toy
    Tug Toy Road Train Member
    7,016
    73,554
    Jul 4, 2015
    Corn field
    I'd be looking at the clutch if you didn't change it with the compressor.
  10. deeretech
    deeretech Bobtail Member
    8
    Sep 25, 2017
    Did you get the problem solved? pressurizing the system with nitrogen and using a spay bottle of soapy water is the best way I've found to find the hard to find leaks.
    There should be a high pressure switch that turns the engine fan on to pull air across it when needed. Just thinking if the fan isn't coming on when your driving (if its hot out and depending on speed) the pressure will get to high and the compressor will shut down.
