I have a 2017 freightliner cascadia dd15 engine and dd12 transmission the truck has started making like a grinding sound but only when I pull a heavy load if im empty the noise goes away but the heavier the load the more intense the sound you can hear it most at low speeds 1-10 miles per hour any idea what it could be ?
weird grinding sound
Discussion in 'Ask An Owner Operator' started by mejiera, Jul 7, 2021.
Empty air bags ...
air bags putting the u joints in a bind
Trucker61016 Thanks this. -
Check all your wheel bearings closely.
Replace the air ride valve then adj. it to correct ride hi. and it should stop making noise?
Are you saying its from the transmission when first starting out from being stopped, or does it sound like back at the drive axles ?
