Well that could have gone a little smoother......
Discussion in 'Ask An Owner Operator' started by Freightlinerbob, Dec 20, 2014.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I hung around till they diagnosed it. Was told it was the rear diff. I told them to go ahead and fix it and then got a room.
    Then they found out on a test drive that the front diff was the problem.
    Because of parts availability and time constraints I had to settle for a pump-less front diff instead of a pump unit like the truck had originally. I hope I don't regret that decision.
    In the end the service manager did what he could to make it right and I figured it best to leave the new rear diff alone than to re instal the original million mile unit. They offered to do that. Had them do a full brake job since it was all apart anyways.
    December has been an expensive month:
    4 trailer tires
    1 alternator
    2 diffs
    Full brake job on the drives.
    3 nights at a motel waiting.
    The bright side:
    I got a pretty good deal at the shop.
    I'll get home for Christmas.
    When I checked into the motel for the third night....
    Happy Gilmore was playing!
  3. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Well, at least now you've got two new diffs instead of 1 new diff and a 1 million mile unit that may have lasted only who knows how much longer? Probably got a better deal on it all told than you would have got doing each diff at separate times. Too bad though that the shop didn't diagnose it correctly... that's a big screw-up on their part.
    Sounds like your truck will be in good shape for the start of the new year though.
    Freightlinerbob Thanks this.
  4. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    That's the way I see it too.
  5. wore out
    wore out Numbered Classic
    15,952
    192,990
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Thing is that gets me is you can tell when a diff hits the floor if that is the problem unit or not. Why did these morons not stop there and make some calls to see how to proceed just saying
    "semi" retired Thanks this.
  6. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I agree. I went over to look at it and visually, there was nothing apparently wrong. They told me they found no traces of metal either. I'm a pretty good wrench but I'm not a mechanic so I deferred to their opinion. But it didn't sit well in the back of my mind.
    When they drained the front diff....they found all the evidence they needed.
    [​IMG][​IMG][​IMG]
    Hurst, wore out and gpsman Thank this.
  7. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Getting mine checked out and serviced when I get home.
    I feel your pain... last July was an expensive month for me as well.
    But at least you know what you have now vs the ticking time bombs in my truck. 1.2 million and mine is still all original. Well maintained and serviced.. but anything can happen.
    Good luck!
    Hurst:smt111
  8. 201
    201 Road Train Member
    12,327
    25,206
    Apr 16, 2014
    high plains colorado
    Most the time, I've found, it's the front axle that goes, and they knew that, but put the rear, rear in (if I follow you)knowing the chances of you wanting that removed was slim. I've seen axles , especially rear ones go for millions of miles, front ones, not so much. I feel bad for you, I think you may have bought new chairs in the break room for the employees. Don't let these guys pull that on you, I would have made them take it out. That's bs.
  9. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    No I don't agree. I think they screwed up. But yes I expected the front to fail before the rear, and it did.
    They cut me a pretty fair deal on the bill so I'm pretty sure there was no malicious intent.
    I just hope their attention to detail in assembly was better than in diagnostics. Time will tell.
  10. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,424
    Mar 23, 2012
    That third picture, felt it in my stomach.
    have a beer for me in that cushy hotel brother.
    ramblingman Thanks this.
  11. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    LOL.
    That third picture......the teeth look like they're on Meth.
    gpsman Thanks this.
