What’s more profitable??
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by iamfargo, Apr 5, 2019.
  1. iamfargo
    iamfargo Light Load Member
    107
    22
    Feb 20, 2019
    So talking with a buddy and going over scenarios.....
    Is it more profitable let’s say your in the Midwest where hopper bottom has loads by the abundance........
    Running a day cab ( meaning can haul about 1-2 more tons Pay load ) with a hopper bottom and just run let’s say 100/300 mile trips let’s SaY1-2 a day
    Or run over the road with a sleeper and haul long haul loads but 1-2 tons less due to weight of sleeper ??
    Experience grain haulers and Ag haulers / farmers please respond and try to if possible give a reason why and your thoughts on it !!
    Thanks
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    The highest rate I’ve received was $75 per ton on a 550 mile (all day) run.
    So that would be say $150, but then you would still have to get back, so a day cab is out in that case.
    Shorter runs $14 per ton, so $28 more. Can do three to five per day. So we’ll say $75 to $125 more per day. And home every night.
    But that’s all theory. It’s the line ups that wreck your plans.
    Some days I plan on five loads, but can not get two in due to lines at the terminals.
    iamfargo Thanks this.
  4. iamfargo
    107
    22
    Feb 20, 2019
    I got you so what you saying it’s better to go with a sleeper because those extra two tons won’t be worth if you get stuck out there on the road 300 miles away ? But that 14 a ton how long were those trips ?
  5. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,522
    May 28, 2015
    Math is hard!
    ♡Barbie♡
  6. iamfargo
    107
    22
    Feb 20, 2019
    Lol
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Depends where you're at, I know for South Dakota you're going to have to gross around 100k to make any money, at least for loads I've seen. I'm assuming the guys running trains and 8 axle setups are getting solid year round contracts for a lot better than you can find on the board, only way it pencils out in my math.
  8. uncleal13
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    About an hour from terminal.
  9. Dennixx
    Dennixx Road Train Member
    4,491
    14,255
    Feb 13, 2010
    twin cities
    If you're gonna run grain you're gonna want a place to rest while you wait.
    Mooseontheloose and uncleal13 Thank this.
  10. Long FLD
    Long FLD Road Train Member
    12,073
    49,857
    Mar 4, 2015
    There isn’t a 2-4K weight difference in a sleeper truck vs a day cab as long as the rest of the truck is the same. At the very least I would want a 36” bunk just in case things went south and you didn’t make it home.
