What am i doing wrong....5th wheel wont budge
Discussion in 'Questions From New Drivers' started by BlackThought, Oct 30, 2017.
  1. BlackThought
    BlackThought Medium Load Member
    562
    462
    Jul 22, 2014
    Memphis,TN
    Raised landing gear higher than normal
    Dumped air
    Pushed switch to slide 5th
    Released tractor
    It still won't budge.
    Currently have a huge gap between my truck and trailer. Trying to improve my 6.8mpg
  3. RedRover
    RedRover Road Train Member
    1,791
    2,612
    Sep 10, 2016
    Corsicana, TX
    Rock it hard like you do the tandems if they are stuck. If you want to slide the 5th wheel forward, first do all of the above and kinda dump the clutch driving forward... should get the pins to release. Once they do, put it on reverse and slowly slide to where you want it to be.
    Be mindful if the trailer is loaded it could be dramatic in terms of distribution of weight. If rocking it doesn't release the pins, I'm sure someone else will have a remedy. Dudes have told me spraying something or other on the tandems and fifth wheel will get them loose but I don't recall what as I always just rock it.
  4. okiedokie
    okiedokie Road Train Member
    11,761
    85,517
    Jun 13, 2011
    PNWET
    Put soapy water or diesel on the slider track.
    tinytim Thanks this.
  5. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    Soak the rails with a heavy duty anti rust petroleum product.....spray and soak it again. The rails are rusted to the frame.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,826
    Sep 10, 2010
    Flint, MI
    Make sure the locking pins are retracting. Lock the diffs. Get in truck and rock it untill the pins release. Slide to whever.
    If that fails unhook from trailer. Release 5th wheel locking pins. Take 5th wheel puller and pull the whole 5th wheel as far back as it will go.
    If it refuses to budge, hammer the metal above the pins to try and get them to release. If that fails to release the pins take to a shop.
  7. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    trying to slide the fifth wheel? Have you checked the obvious have the pins slid out yet that hold the 5th wheel? that will stop it moving i wouldn't touch anything just move the truck forward and it should slide perhaps if it hasn't moved for a long time there is a lot of dirt in there it may take abit of water or lubricant to loosen things up then try it again.
    Lepton1 Thanks this.
  8. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Soap and water on the locking pins and tracks.
    Once you have a nice gap between the fifth wheel and trailer,rocking the truck slowly should release the pins.
    FishFanatic27 Thanks this.
  9. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
    Lock the differential so you have slightly more torque...gently rock the pins loose.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I find it easier to just release/park the trailer. Then move ahead disengage the fifth slide pins, and move it by hand with a large pry bar or crow bar. Then you can put it exactly where you want it.
    It is very difficult to move with a trailer on it unless you can get all the weight off it and at the same time not pulling up on it. Has to be neutral weight.
    tinytim, Getsinyourblood and ChaoSS Thank this.
  11. 1278PA
    1278PA Road Train Member
    1,170
    1,026
    Dec 5, 2015
    PB Blaster spray is awesome been using it for close to 20 years.
