What are Mph for each gear 1-10?
Discussion in 'Questions To Truckers From The General Public' started by Magnetron, Jan 7, 2009.
  1. Magnetron
    Magnetron Bobtail Member
    What are the travel speed for Eaton Fuller Transmisson
    in MPH 1st gear 2nd 3rd 4th 5th 6th 7th 8th 9th 10th
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Here's a good rule of thumb for a ten speed (applies to 5th through 10th gear):
    Look at the numbers on the speedometer, starting at 5mph would be 5th gear. 0 + 5 = 5
    15 mph would be sixth. 1 + 5 = 6
    25 mph is seventh. 2 + 5 = 7
    ...and so on.
  4. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    There's no two trucks the same. You just have to drive and find out.
    Kabar Thanks this.
  5. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    What would be 60mph?
  6. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    theres no gear for 60:biggrin_25525:
    you have to stop accelerating once you hit 5+5= 10th!!:yes2557:
  7. sidewinder429
    sidewinder429 Light Load Member
    68
    32
    Jul 18, 2008
    Watch your speedometer and tachometer. 1500 rpm is the top end of each gear and 12-1300 is usually the bottom. watch the relationship between the tach and speedo while in each gear, that will tell you what mph range you have for each gear. And yes 5-10 of the gears add 2 digits of the mph together is close in most of the 10 speed trucks. but there will be some differences.
  8. lilillill
    5,642
    13,470
    Nov 7, 2007
    Shhh! That's the top secret eleventh gear that newbies don't have access to until they've put away a half a million miles.:biggrin_25525:
  9. MACK E-6
    48,162
    219,955
    Gasman's right. Truck and heavy equipment are like women. Every one is different and has it's own temperament.
    You can't really give a uniform answer to a question like that. It depends on the truck's driveline gearing.
  10. Magnetron
    I float the Gears and Shift by listening to engine it a Bad Habbit....it still good to know MPH for the selected GeaR
  11. dangerous dave
    dangerous dave Light Load Member
    127
    51
    Jul 20, 2008
    Houston, TX
    Lots of difference between a 2.93 rear gear and a 4.33. Also 10 direct and 10 OD. Also even on two trucks geared alike the speedo's can each be off a mile or two in opposite directions. Watch as you run up threw gears, memorize. Thats the only solution.
    Dave
