What are the Specs of Con-Way trucks
Discussion in 'Con-Way' started by snowbird_89, Apr 14, 2010.
  1. snowbird_89
    snowbird_89 Road Train Member
    1,028
    824
    Aug 21, 2009
    Massachusetts
    I'm just curious because I have an interview with them soon. I know they mostly drive Sterlings.
  3. jakebrake12
    jakebrake12 Road Train Member
    1,576
    1,047
    Feb 15, 2008
    I95
    Hahaha.. It varies depending on year but most of what we have now are 2004 and up now but they're all stripped - this company is not known for luxurious trucks.
    2007 and older are 455 Detroits according to the plate on the engine but they're cut back to god knows what. 7 speed transmission with no splitter, no jake, A/C on 02 and up, no cruise, don't pull very good for the most part, set at 62 but my GPS says more like 60-61 depending on the truck, but they do the job.
    The 2008's are 10 speeds and have a nicer seat and are just better trucks. The 2009/2010 are the Freightliners which are the nicest trucks we've ever had. They also have 10 speeds and are the only trucks we have with cruise - they also have a company provided XM which was surprising. The newest trucks go on the longest line-haul runs - I run a mid range run so I have an 04 but I like it. I would get the next brand new one if I had bid a long run but I didn't.
    If you do decide to work here don't worry about the trucks - they are what they are - stripped LTL company trucks. They get the job done and make you a lot of money if you stick around for a while..
    Jeff505 Thanks this.
  4. drgeerjmmr
    drgeerjmmr Bobtail Member
    13
    16
    Oct 9, 2009
    not sure of the year but we still have some 6 speeds at my barn. I only drove a 10 or 9 speed with splitter before, so it has been interesting getting used to these 7 and 6 speeds. There are some old school trucks around too- the 480- series. those are real interesting to drive.. With the shortage of equipment, I could imagine they are hesitant on retiring trucks. Over all they run ok and like jakebrake said- make you a lot of money. Even just starting out the money is pretty descent..
  5. snowbird_89
    1,028
    824
    Aug 21, 2009
    Massachusetts
    no jake brakes? i am doomed!
  6. jakebrake12
    1,576
    1,047
    Feb 15, 2008
    I95
    It's a long story but I was given my user name by another driver here after whining about not having them..
  7. snowbird_89
    1,028
    824
    Aug 21, 2009
    Massachusetts
    Are shifting the 7 speeds easy? At school, I had a hard time double clutching a 10 speed Mack. So i did the test in an automatic.
  8. jakebrake12
    1,576
    1,047
    Feb 15, 2008
    I95
    Bout the same I guess just no splitter. They seem to vary a lot truck to truck.
  9. JustSonny
    JustSonny Big Dummy
    6,038
    5,785
    Oct 22, 2009
    Troutman NC
    What's up?
  10. jakebrake12
    1,576
    1,047
    Feb 15, 2008
    I95
    They want to fit all the trailers with the e-track system, go paperless, and they just got like 1500 of those new Freightliners so they wanna get some cash. We just watched a video about this the other day but I only caught a little since I was heading out the door..
    This company wastes a lot of money at times if you ask me.
    JustSonny Thanks this.
  11. nikondvr
    nikondvr Light Load Member
    173
    69
    Feb 7, 2007
    What jake said about it varies truck to truck is correct. Mine shifts like a dream but some of the others tend to like to hang up in gears and be a pain to get back to neutral. And the new Freightshakers actually have fuel gauges to go with that 10 spd and cruise. Imagine that.
