What are these "retarders" and how do
Discussion in 'Questions From New Drivers' started by nwcountry, Oct 22, 2009.
  1. nwcountry
    nwcountry hot-flash
    449
    65
    Sep 11, 2009
    Winchester Oregon
    they compare to the breaking system? I hadn't ever heard of these things til I was reading my CDL Manual. I read they help slow the truck reducing the need for using your breaks. I also read don't use them on slick surfaces as they can cause you to skid. They're on the "drive wheels" which I don't know which those are(I hear you spitting your coffee out there, no laughing, this is serious stuff:biggrin_2559:) Are retarders also called "jake brakes"? I have heard and heard of those but I don't know what they are or how they work.
    So after you guys tell me what they are tell me how and when you use them? I'm just learning so much:biggrin_2558: Aren't you all glad I am hear to keep you up on your educations, LOL!!!!! Really though, all fun aside, I surely appreciate all the help I get here on the forum:biggrin_255: Denise
  3. Rat Fink
    Rat Fink Light Load Member
    190
    122
    Nov 18, 2008
    Lethbridge, AB
    Engine retarders, engine brakes, jake brakes, and compression brakes are all terms used for the same device. Basically, they slow the engine down without applying braking directly on the wheels. By slowing down the engine, you will be indirectly slowing down the rest of the drivetrain and your vehicle will slow down as a result of it.
    On slippery conditions they can slow things down to the point where your wheels lose traction and can lock up!!! (just as if you had slammed on your brakes).
    Some jake brakes have multiple settings. On dry pavement I'm usually on the highest setting. On slippery pavement (wet/snow/ice), I'm either on the lowest setting or I have them turned off completely.
    Your drive axles are the back axles on your tractor. A rear wheel drive car/truck has the back axle being the drive axle. A front wheel drive car has the front axle as being the drive axle. It's the axle that drives the vehicle.
  4. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    Hell, I always thought the retarders were the guys/gals who worked dispatch, aka driver managers!:biggrin_2559:
    Oh wait, those are not retarders, they are just re tards...:biggrin_25522:
  5. beancounter
    beancounter Light Load Member
    182
    71
    Sep 4, 2009
    Greenville, MI
    Yeah, but she's talkin about engine retarders. I think that actually might be confused with a mechanic in a Werner maintentance garage.
  6. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Yeah that is a jake brake. The guy who invented them was named jacobson I believe or close to that anyway. He has a patent on them and they are called jakes for short, but it is a engine retarder that helps the truck descend on mountains and saves the braking system. Even the Army had them on the 9-15's semis in the 1980's.
    Intothesunset and rookietrucker Thank this.
  7. nwcountry
    nwcountry hot-flash
    449
    65
    Sep 11, 2009
    Winchester Oregon
    Thanks so much!! Lots of great info RF:) I think basically, you can't use those jake brakes in city limits. I will have to check on that.
    ttyl, denise:biggrin_25525:
  8. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I don't use the engine brake except doing down grades. I really don't see a need for it and I did alot of city driving. I'd much rather time the lights and just cruise through. Besides, most times I would end up at the same place and the same time as the truck racer. Some towns and cities will allow engine brakes and some don't. Some won't allow them when you really need them but that's the law.
    When you get out on the road you'll start learning downhill operations. This is where you'll want the engine brake so you'll have plenty of friction brakes to stop in an emergency. The ideal situation is to go down the hill and tapping the foot brakes only a couple of times. It's easy to do but you have to pay attention on what's going on around you. You'll also learn that driving a truck using all your senses so you'll use sight, smell, sound, and feel especially going down the mountains.
    D.Tibbitt, TravR1 and notarps4me Thank this.
  9. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    they arent legal everywhere cuz there so #### loud
    TravR1 Thanks this.
  10. Jack Smithton
    Jack Smithton Light Load Member
    256
    167
    Jan 1, 2009
    so cal
    I try to use the Jacobson ("jake") brake (engine retarder) all the way down and add a little trailer brakes if necessary. Then the tractor brakes are always cool. If I have to apply the tractor brakes more than a few times, I slow down with my still-cool brakes, then drop a gear so the engine can pull the speed down better, just as it is more efficient going uphill in a lower gear.
    BTW - The way I understand it, the engine retarder changes how the valves open and close. So, instead of the engine using compression/explosion to produce power, it uses compression/release to the atmosphere (with attendant noise) to "use up" the energy created by the truck going downhill.
    Hard to believe that it is still allowed (by any company or by the government, which knows best :biggrin_2552:), to go down a big hill without an engine retarder. Coming east out of San Diego, there is a hill on I-8 from about 4200 feet. Not that bad, 6 or 8 miles at 6% I guess, but the speed limit is 35 for trucks. If you are grossed out w/ no engine retarder, you have to go 12 mph in 4th gear at 2000 rpm w/ some trailer brakes applied, if you want to save the tractor brakes. Did this with 9000 gallons of gasoline - dispatch, all wrapped around "don't go over 55 ever, don't stop to eat or for any other reason while loaded, lock your doors when loading/unloading," etc., etc., never worried about sending a truck "over the hill" w/o an engine retarder.
