What brand of oil do you run?
Discussion in 'Ask An Owner Operator' started by fireba11, Aug 29, 2012.
  1. fireba11
    fireba11 Heavy Load Member
    864
    541
    Jul 30, 2007
    Tracy City, TN
    I was getting my oil changed at a Petro in California and the service manager was trying to talk me into using Mobil 1 oil. I have always used Shell Rotella and would not change. The service manager said that most owner operators now days use Mobil 1, I told him that I find this hard to believe so I thought I would put this out there and see what you guys use.
    Tnx
    Tim
  3. rollin coal
    rollin coal Road Train Member
    13,117
    26,091
    Mar 29, 2008
    TN
  4. Dice1
    Dice1 Road Train Member
    1,315
    609
    Jul 1, 2011
    Bessemer City, NC
    Mobil One Synthetic 5W40
    Mid-service lube (filter change and oil analysis) 15k to 20k miles
    Change oil every 80k to 100k miles
    Worth around 1/2 mpg over conventional motor oil and makes for easier starting in the winter.
    Will make a small oil leak into a big one due to being thinner.
    fireba11 Thanks this.
  5. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    Schaeffer's 9000 series 5W40 full synthetic. Rotella won't ever see the inside of my engine again. The oil samples always came back with many bad catagories and it had a burnt smell after 10,000 miles. Not a single problem with Schaeffer's in the 450,000+ miles I've been running it.
    Gsm, cableclown and fireba11 Thank this.
  6. jpracer1
    jpracer1 Medium Load Member
    439
    198
    Nov 26, 2009
    rotella...
  7. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    rotella won't see my engine again either. it can't take the heat. engine runs hotter, and pressure runs lower. engine sounds loud and performance and mileage go down.
    mobil 1 for me.
    and everywhere i've been that does oil changes around these parts. are all using mobil 1. some even have a choice of delo400. but i don't think i've seen anyone using rotella.
  8. FREEBRD
    FREEBRD Medium Load Member
    499
    116
    Oct 18, 2007
    Lafollette tn
    Mobil1 all the way!
  9. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Schaeffer products all the way. Oil, gear lube, and grease.
    fireba11 and cableclown Thank this.
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Here we go again.... another chevy vs ford vs dodge debate.:biggrin_25516:
    There are so many good oils out there that there is no "best" oil. Besides, as much as marketing would like to say one thing, virtually all the base mineral oil for the North American market is made by one company.... Motiva (shell) out of Port Arthur, TX. Easy to look up and prove. Same for most of the additive packages for N. America... most of them are put together by one company... Infineum. Sure, there will be very minor differences between brands, but if you took all the big name brand HDEO and run a virgin oil analysis on all of them, they would be strikingly similar. Delo edges out the others when it comes to zinc content (anti-wear additive), but only slightly. The CJ-4 specification does not allow much leeway in engine oil formulation. It isn't like it was 20-30 years ago. Just find a recognized oil that is a bargain and stick with it.
    I will concede that some engines will prefer a particular brand. It is very similar to some .22 rifles shoot best with a particular brand of ammunition, while that same ammunition doesn't perform as well in another rifle. Just one of life's little mysteries. But all the major oils are good oils. If something is working good for you, it is cost effective, then by all means, stick with it. I have my preference, which will probably not be some other's preference. Doesn't make either of us wrong.
    To the original post, Mobil Delvac 1 is a solid synthetic oil. But so is Schaeffer 9000, and the synthetics offered by the other name brands. But the only real advantage to going with a much higher priced synthetic oil, is if you are running a bypass filter, doing regular oil sampling, and extending your oil drains. Within a typical 20,000 - 25,000 mile (or even less) OCI like most people use, there is very little benefit to spending more money for a full synthetic. A synthetic blend, maybe, but not a full synthetic.
    And as to whether one brand of synthetic is a "true" synthetic or not, is pure marketing junk. There are two major groups of synthetic.. Group III and Group IV. There is also Group V, but none of that is made for engine use. Group III is made from mineral oil, and Group IV is made from natural gas. Both are very similar in performance and, truth be told, all of even the Group IV synthetics like Mobil, Amsoil, Schaeffer 9000, etc also have a mix of Group III in them. Schaeffer is honest about it, they make it quite clear that their 9000 oil is a 75% Group IV and 25% Group III. That is required to keep the additive package in suspension, as Group IV's by themselves are not the greatest for keeping additives in suspension. All of the brand name synthetics are great oils. I recommend them, but only if one has extreme operating conditions that require a synthetic, or they are going for long drain intervals. Otherwise it is not money well spent. Unless you just like spending money and it makes you feel better.
  11. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,138
    Jan 30, 2011
    Whatever is $11.88/gal at Walmart. Shell, Chevron, and Mobil seem to rotate on sale.
    Dead dinosaurs is dead dinosaurs. The rest is marketing budget.
