What brands to look for (equipment)
Discussion in 'Questions From New Drivers' started by CiRca, Jun 5, 2010.
  1. CiRca
    CiRca Bobtail Member
    5
    Dayton,OH
    Okay as newbie I have been lurking this forum for awhile now. I've seen some of the info scattered across the forum in different areas and some I have yet to find. So how about making a list of brands to look for when it comes to equipment?
    Rain Gear:
    Flashlight:
    CB Radio:
    Trucker Atlas: Randy McNally- seems to be the best choice
    GPS:
    If you have recomendations please post up. Also if there is something else that should be added to the list please let me know. These are just a few that I have had questions about.
  3. Saddle Tramp
    Saddle Tramp Medium Load Member
    590
    235
    Jul 13, 2009
    laurel, nebraska
    :biggrin_25514:get a good weather proof, heavy duty rain ware.
    when you drive through heavy rain i would get a pair of rubber boots.
    Get a flashlight like the police have, very dependable.
    My perfence is a cobra 25=29, with a good ant.
    Rand Mc NALLY atlas, it has all the information that you need.
    GPS== only good for inner city driving. I suppose any brand will work.:biggrin_25514:
  4. slo-poke
    slo-poke Light Load Member
    76
    43
    May 27, 2010
    Polk City FL
    heavy duty rain Gear
    Mag-lite flashlight
    I have a conex and a Galaxy CB at this time
    Rand Mcnally great map
    I like engineer boots or cowboy boots easy on and of.
    couple pair of good work gloves
    the list could go on for ever!
  5. universal10
    universal10 Light Load Member
    85
    32
    Dec 5, 2009
    winnipeg
  6. Ramblin' Redneck
    Ramblin' Redneck Medium Load Member
    361
    243
    Apr 18, 2010
    So.IL
    Rain gear:
    I have a rain suit that I bought a decade ago when I was driving wreckers. It wasn't cheap...but wasn't too terribly expensive, either. It's a heavy duty PVC 3-piece (pants, jacket, hood) that I got at Home Depot...heavy weight PVC over a cloth-feeling inside. Only problem I had was the cheap retaining system on the pants (were similar to bib overalls, but with rubber grommets). I bought a pair of heavy duty suspenders to clip onto the waistline of the pants and I've been getting great use out of them since. If you buy the cheap, thin, light weight crap at Wally World, you'll get wet the first time you wear it.
    As for boots, I've never bought "rain boots". I either wear waterproof work boots, or my feet get wet. I like slip-on boots for easy on/easy off. If you live in your truck, kicking your boots off before you climb back into the sleeper will help keep the "living quarters" cleaner. Rocky USED to have my favorite boots...100% waterproof & fit like a glove, but they changed their cut. They are still good boots, the new ones just aren't as comfortable on my feet as the old ones of the same size & model.
    (also available in steel toe)
    Flashlight:
    Mag Lights are good quality. I've got one somewhere that I actually found at the bottom of a shallow spot in a lake...and it worked. The one in the truck is one of the new ones with the LED light...seems to do alright, but it isn't as bright as the traditional 4-D cell lights. I've also got a 6-D cell one somewhere, but it's just too darned heavy to lug around all of the time.
    CB Radio:
    As long as people near you can understand what you are saying when you key up, and you can hear people near you when they talk, that is all you really need. I'd spend more attention on the antenna and coax than on the radio. As far as radios are concerned, what features do you want? You can buy anything from a simple 40 channel radio, to a radio with side bands, echo, talkback, etc. You don't NEED all of that extra stuff...never heard about any shipper/receiver that required you to be on a side band to communicate with 'em. A hint of echo helps you stand out from the crowd of faceless voices...but too much and nobody can understand you. It doesn't take a lot of echo to be "too much", either. Talkback is nice...lets you monitor your broadcasts...but if you aren't careful, it will lead to feedback.
    One other thing: Get a noise canceling mic (like an Astatic or Road King)...sounds a lot clearer when you talk, since they don't pick up as much background noise.
    Trucker Atlas:
    Rand McNally Delux Motor Carriers' Road Atlas. It's the laminated one. I generally buy a new one for the truck every 4 years, due to regulation and map changes...NOT from the map wearing out. If you waste your money on the less expensive paper version, you'll end up replacing it AT LEAST once a year (possibly 2 or 3 times) because the pages get torn up or it falls apart...so you end up paying MORE than if you had just bought the laminated one to begin with.
    GPS:
    I'm going to second the Garmin 465T, as it's what I have and it works pretty good. There are other truck-oriented GPS devices, too. If you are buying it with the intent to use it in a truck, spend the money and get the truck-oriented one. It will have more relevant information than a car-oriented unit...however it STILL won't be 100%. Road information (size & weight limits) aren't programmed in for every road, so you STILL have to pay attention to what you are doing. Don't turn on a road you aren't supposed to be on just because the GPS told you to....it's still your ticket (or worse) if you blindly follow that electronic gadget. The one nice thing about GPS is that you always know where you are, and searching for the next exit/fuel stop/repair location is just a tap of the screen away.
  7. CiRca
    5
    Dayton,OH
    Very good info thank you
  8. sidewinder
    sidewinder Bobtail Member
    28
    6
    Apr 4, 2008
    LaGrange ga
    Rain Gear: frogg toggs and a good small umbrella
    Flashlight: Mag light, at least a 3 d cell and a mini mag
    CB Radio: i buy a new cobra 29 ltd every 10 years or when they stop working
    Trucker Atlas: Randy McNally or last years when it goes on sale
    GPS: using a tom tom now, but wouldnt reccomend it, dosent have truck routing
  9. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    Pay attention to this !!!!!!!! If you feel you need a GPS as a n00b make sure the model you choose has truck routing on it !!
  10. Ramblin' Redneck
    361
    243
    Apr 18, 2010
    So.IL
    Whether it has truck routing or not, you are STILL the one behind the wheel.
    I've got the truck version of the Garmin (465T) and it ain't perfect either. It does pretty well on the interstates, but once you get off heading through the sticks, it picks some pretty funky routes. Most of the time, by the time it corrects itself enough to pick the route I was already going to take, it is 10-15 minutes faster than its previously selected "fastest route". Pretty sad, considering a lot of my trips are less than a couple hours in length.:biggrin_2559:
    Mostly, I just use it for a speedometer (more accurate than the one in the dash) and as a map to see what's around me (without programing in any route information) or to search for fuel stops if I'm in unfamiliar territory.
  11. groundpounder
    2,569
    1,039
    Nov 13, 2009
    I bought a low end Garmin for the Jeep (it was almost free w/all my Loves points) ended up bringing it out in the Pete w/me.....I'll use it as kind of a heads up like late at night when I searching for a street I need to turn on.....I swear those street signs get smaller at night when I'm tired !! Knowing that the turn is coming up helps a lot sometimes..
