I've uploaded a picture of the INNER dual tire blowout. It was a city bus. It came out of the shop 3700 miles prior, less than a month. The mechanic measured the tread depths RRI = 12/32 RRO = 17/32. When blowout happened the RRO was measured at 9/32. The company fired the mechanic stating he falsified the tread depth and the tire should been replaced. Is it possible that if the inner dual was low psi could it have worn to that degree and blowout? Any ideas please.
What caused this Blowout on inner rear dual bus tire
Discussion in 'Questions To Truckers From The General Public' started by Perryrob1, Apr 8, 2020.
Its possible.
You need to have tires that like each other. Yea high on both of them.
If one is too low the other gets overworked.
BOOM.Perryrob1 Thanks this. -
The inner tire is the one that blew AND it was the one with the lower tread 12/32. I'm presuming the inner tire carries more weight, however the outer tire (17/32) had to of been low psi for the inner to be overworked?
Yes, low psi in the inner tire could have been the problem. Another possibility could have been a misreading on the tread depth gauge. The tread needs to be measured on different grooves to get a better reading, especially if the used tire hasn’t been wearing evenly.
Personally I think firing the mechanic was too excessive, unless perhaps that mechanic had plenty of complaints. I’d argue that the driver could have prevented all of this if he actually inspected his equipment as it is required by law. The tire shows signs of excessive wear, and he should have noticed this wear days before it blew up. Just my 2 cents.HoneyBadger67, Perryrob1 and Tb0n3 Thank this. -
The reason the lower tread tire went bald is due to repetitive scraping or skipping. Tires that are not making full contact with the road will skip and wear off the tire quickly.Cowboyrich and Perryrob1 Thank this.
Actually all if his tire measurements went up from what a previous mechanic wrote down 6000 miles prior. That tire was at 8/32 6000 miles prior. The vehicle was in shop prior but no record of tire change from other mechs. They take the reading in teams of 2. One measures one writes down. True the last 4 drivers were disciplined for not performing pm. However. That bus was driven by 10 different drivers that month. I'm arguing that since the first 6 drivers didn't annotate worn inner tire, then his measurements had to be good.PE_T Thanks this.
