what causes the fan to keep going on and off on a c15 cat.
Discussion in 'Kenworth Forum' started by kimbo7, Apr 17, 2013.
  1. kimbo7
    kimbo7 Bobtail Member
    9
    The fan keeps jumping on and off when it gets ready. Could this be because of a bad fan switch? Any other ideas of what it could be? Advice is greatly appreciated.
  3. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    is your ac on whats your enigine temp during this
  4. troyobray
    troyobray Bobtail Member
    13
    Nov 5, 2008
    i had this problem. i had a leak inside the fan hub that only leaked when engine running. i rebuilt fan hub with a kitmaster gold top rebuild kit. once i had it apart i could see the plastic part that had o-rings on it that had all but fallen apart.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    ground fan solenoid maybe. maybe
  6. kimbo7
    9
    Thanks for all the replies i will try them out.
  7. kimbo7
    9
    the fan keeps jumping on and off even when the ac isn't on. It is like there is a short somewhere. Any suggestions. Temp isn't going up.
  8. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Is this a 2007 or newer truck? We have seen lots of issues with the power steer temp sender, or more likely in the wiring, it is tied into the a/c and an open in the circuit will turn the fan on. We normaly bypass this at the fan on pressure switch at the a/c copressor, just unplug the wiring to the p/s res and plug the connector from the main loomed harness into the a/c fan switch (orange pressure switch).
  9. kimbo7
    9
    what is the p/s res and where is it located? I have a 2005 w9
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    sounds like a ground wire.
  11. kwcam
    193
    145
    Dec 29, 2012
    at the shop
    p/s is power steering , res=reservour. 2005 would not have a temp sensor there, starts on 2007 and up.
    Your 05 could have a bad/intermittant open in the harness from the a/c switches at the front left corner of the rad to the connector plug at the engine. when the fan is not running (eng. running) just wiggle the harness from the a/c switches back to the plug/connector at the front of the engine, if the fan kicks in test it again to be sure, we replace lots of these as the coolant level wiring is some times in this harness.
