What causes wind push from a truck passing you?
Discussion in 'Questions From New Drivers' started by runfrombears, May 7, 2011.
  1. runfrombears
    runfrombears Bobtail Member
    5
    Dallas, OR
    I know this is very basic science here. I'm just trying to visualize an air wake. It happens before they pass me, you feel the pull to the opposite side and you know someone is passing you. So if it happens before they pass it means its disturbing your trucks wake, but you would think the pull would be towards them not away. Is there a name for this? Thanks
  3. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    vortex..???
    http://en.wikipedia.org/wiki/Vortex
    http://www.sti.nasa.gov/tto/Spinoff2008/t_3.html
    it happens with planes as it does to trucks..
  4. ZippyNH
    ZippyNH Medium Load Member
    408
    121
    Aug 8, 2010
    Southern NH
    Wind?!
    You answered your own question....
  5. ZippyNH
    408
    121
    Aug 8, 2010
    Southern NH
    To be more precise....when wind is sped up...the pressure is lowered...same as on a plane....so once you get beyond the pressure wave on the front (like the one dolphins ride on infront of boats) you get that sucked in feeling....then at the backed....you get into the disturbed airflow area...and you get the big buffets, like when you are too close.
  6. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    Bow wave... just like you see from a boat.
  7. walstib
    walstib Darkstar
    The air behaves very much like water, cept you can't see it(turbulence is just a plane flying thru waves like a boat on a rough lake)...The truck displaces air as a passing boat would...
  8. Mr Ed
    Mr Ed Road Train Member
    1,380
    1,630
    Apr 6, 2009
    Retired in Taunton Ma
    Sometimes I have wind turbulence inside the truck. What causes that?
  9. celticwolf
    celticwolf Road Train Member
    1,527
    642
    Oct 10, 2010
    Kittrell, NC
    truck stop food...
    Panhandle flash and Freebird135 Thank this.
  10. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    your truck enters the airspace in front of it. the air moves around the front of the truck and is compacted with the existing air on the side of the truck.
    then another truck comes along and displaces that compressed air on the side of your truck. This compressed the air even more between the two truckss and pushes your truck away from the other...
    The same way it gets so much more windy when the wind is funneled between buildings in cities.
    Mikeeee
  11. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    Your window might be open.:biggrin_25523:
