What comp. has the shortest refresher program
Discussion in 'Experienced Truckers' Advice' started by ThatboyB, Oct 22, 2013.
  1. ThatboyB
    ThatboyB Bobtail Member
    48
    Jun 2, 2009
    Houston,Tx
    I have been off the road since 09 Watkins Shepard says 10 days orientation then you test out and get a truck ptl says orientation then you and someone else that needs refreshing goes out for about a week and a half then come back and test out I live in Houston but I'm willing to go anywhere i have flat van and tanker exp.?
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Some may have a "fixed time" regardless, some may allow the a trainer to decide you're good to go once you've demonstrated you can back and operate the truck better then he can. I don't know. Probably worth calling around to a half dozen of them to get a sense of the normal practice for refresher courses. But a carrier may want to see a required minimum hours or, they may simply want to see a successful completion (pass) record so might better get more info from the prospective employer as to what they are looking for first then call some schools.
    ThatboyB Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    77,061
    180,126
    Aug 28, 2011
    Henderson, NV & Orient
    Don't know how long the refresher is, but National Carriers also has one.
    Since you have tanker, check with Schneider tanker division; Schneider does have refresher.
    Check with SVTN also.
    Doubt if anything shorter than Watkins & Shepard. Their 2 wk. orientation is fast paced and you have to hit the books & watch films at night in the hotel, so be prepared to get down to business. They also have a flatbed division.
    PTL is pretty laid back and the trucks have APU's.
