What daily physical activites does your job require of you?
Discussion in 'Questions From New Drivers' started by alone, Jul 2, 2014.
  1. alone
    alone Light Load Member
    I've searched around a lot for this but cannot seem to find what I am looking for. Most companies either list they just want you to have passed the DOT physical and in addition to that, they want you to pass their physical assessment.
    What I need is to know the daily physical requirements of OTR truck drivers. Specifically tanker and dry van drivers as those are what I am interested in at the moment. If dryvan, I'd be looking for 98%+ no touch freight so the truck will likely stay rolling.
    The reason I need this information is I am applying for funding for school. The WIA people want to know why I cannot do automotive mechanic work anymore. I will be upfront about it, I have a bad back, which means I can't work standing on my feet for extended periods of time (8-10+ hours daily) and I can't repetitively bend at the waste for those same hours daily. These are extremely common physical things you are required to do in that industry.
    I can easily find a lot of information about the automotive side and its daily physical requirements, but the trucking industry doesn't seem to list information about the daily job duties (I'm guessing because it varies wildly form one job to the next- some of which is no touch friend for example). I discussed this a little bit with the dr. at the DOT physical and he didn't seem concerned with my back problems. I did a couple of squats and bent over and touched my toes as he watched my form from the back and side.
    I've found a few examples of the companies work assessments (Schneider and Swift for example). They each have you do things like lift a weight from floor to waist x3 reps. Then waist to shoulder x3 reps. Squat under a platform x2 reps. Step up onto a platform to simulate stepping onto a trucks step or trailer, etc.. Basically generic things, some of which you actually will do daily, some of which you might very rarely, if ever do. I seriously doubt I would fail any kind of test like this.
    So please, can you list what type of trailer you pull, and what your normal physical daily activities are? I would greatly appreciate this information.
    tman78 Thanks this.
  3. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,905
    48,636
    Dec 8, 2012
    hunting...../ retired
    It isn't the daily bending , squatting , moving that OTR will do that will bother you...But , with a bad back it's gonna be the constant sitting for hours , without any exercise that will do you in...Trucking is not a job for someone with back problems already to even consider , but in the end it's your choice...I drove trucks for over 30 years...retired in 2011 from doing it, I wasn't OTR.... I did food service delivery for GSF for 33 years , and that meant I finger-printed 10's of thousands of boxes in that length of time...if you have a bad back now...IMHO , trucking even OTR would only make matters worse for you...that's my take , and it's just an opinion...Good Luck!
    peterd Thanks this.
  4. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Best listen to tony the trucker dude. When you have to climb down outta the truck after 7 1/2 hours your legs and back are gonna be stiff.I recommend trucking gig where you dont do heavy lifting or sit for extended periods in a seat.My back hurt a lot when I was OTR. Now that Im local or 3 state radius I feel better mix of seat sitting,walking,moderate to light lifting keeps my back loose and worked out. Recommend local gig and sleep at home on a firm stearns & foster bed.Pulling pallets around for me isnt as bad on my back as bending over a fender of a car for 3 hours.JMO
    Tonythetruckerdude Thanks this.
  5. GenericUserName
    GenericUserName Road Train Member
    1,543
    13,065
    May 17, 2014
    Santa Monica, CA
    Sometimes i have to juggle stuff such as carry a drink the large 44oz ones out of the truck stop to my truck which is easily an exhausting 7000 centimeters away. Oftentimes on physically strenuous days i have to carry the large 44oz'r in one hand and a hotdog or snack in the other one.
    Its rough man.
    crxdc, tman78 and blairandgretchen Thank this.
  6. TexTrucker
    TexTrucker Medium Load Member
    531
    412
    Jul 29, 2009
    Houston, Tx
    I'll just answer the question and dispel a misconception you have.
    I pull a reefer across 48. My company does not want us moving freight. However there are times we have to oversee and count it going in or out. This usually entails 2-3 hrs standing on a cement floor, usually frozen.
    I also am responsible for making sure my load is secure with load locks, which means I have to climb in and out of my trailer. Sliding the tandems also requires me to access the underside of the trailer. Our trailers are equipped with an air release, which makes it easier. Not all companies have this. There may be times when you have to crawl under the trailer for various things, like getting frozen brakes to release. The tree may be other things that I'm not mentioning off the top of my head.
    The misconception... 98% no touch doesn't mean your truck will stay moving. You will still have live loads and unloads, times when they can't find you a load, especially on holidays.
    peterd and tman78 Thank this.
  7. GenericUserName
    1,543
    13,065
    May 17, 2014
    Santa Monica, CA
    Ya load bars. Now there is a physically strenuous task! ####### super truckers.
  8. Tonythetruckerdude
    2,905
    48,636
    Dec 8, 2012
    You know...it would be nice for you to keep your posts on the thread topic being discussed....not just silly childish comments....the OP asked a legitimate question...try and give legitimate answers please....
    tman78 Thanks this.
  9. GenericUserName
    1,543
    13,065
    May 17, 2014
    Santa Monica, CA
    My legitimate answer is that there is essentially zero physical requirements for OTR trucking. It is my assertion that if the few physical tasks throughout the job are considered enough labor to be worth mentioning then there is a serious problem with the health of the person claiming such things.
    browndawg Thanks this.
  10. Tonythetruckerdude
    2,905
    48,636
    Dec 8, 2012
    And you base that on what...a few months of experience , and maybe , just maybe 50,000 or so miles.....your assertion carries no weight...you have no idea of the long term effects of OTR driving...lots of drivers wind-up with terrible back trouble after years of driving , and for the simple reason that they carried a wallet in their back pocket , making ( over-time ) their hips / and spine to be out of adjustment..and that's just 1 simple example....But at least we're on topic now...Thanks.....
    that's wind-up..not wing-up...fixed it though....
    GenericUserName Thanks this.
  11. browndawg
    browndawg Medium Load Member
    676
    1,213
    Dec 20, 2013
    Rock Island, IL
    I seen the name of this thread and I thought this had to be a troll or a joke..... but much to my amazement..............
